Results 1 to 7 of 7
    Nov 2016
    Franklin North Carolina
    Default Is there a belt guard for a 2020 rt Limited
    Is there a belt guard for a 2020 RT Limited. I can't seem to find one
    Dec 2020
    Hartwell, Ga
    Nov 2016
    thank you shooter. I just ordered
    Apr 2021
    Bartlett, TN
    Doc,
    Curious of your experience with the belt guard. I put one on mine and ended up taking it off because it rubbed on the tire so bad. I'm thinking about ordering another one and trying again because I like the idea but there just isn't a lot of clearance between the tire and the belt for mistakes during install. My tire had rubbed a pretty good gouge in the belt guard near the bend, so obviously I must have installed it too close to the tire somehow, but man I caught myself triple checking that on install.
    2021 Spyder RT-L Deep Marsalsa Metalic
    Apr 2016
    Albany NY
    Use a heat gun to bend & adjust. It is a tricky install.
    Active Member SpyderGoldwingOwner's Avatar
    Jul 2021
    Texas
    How hard is the guard to put on? Do you need a lift?
    2020 Can-Am Spyder RT
    2018 Honda Goldwing DCT
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    I did mine without a lift. Pretty easy. I had to lay next to the bike - I finished it this am, and now it's raining - so I won't ride it until this coming week. I did have to trim it to go around the welds. It is a smart idea - but the fit is real tight.
    2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
    2021 RT Limited , Marsala Red/Black
