Results 1 to 5 of 5
    Apr 2019
    Ohio
    Default Recommend any Videos on brake pad replacement?
    Anyone know of a trusted video on replacing front and rear brake pads on a spyder, specifically a 2019 F3L?
    Thanks
    Poasttown
    Feb 2019
    Portland, Oregon
    The fronts are easy - remove the wheel and there they are. Unscrew the pin that holds the spring clip (remember and/or take a photo of the clip's orientation) remove it and then slide the pads out. If you are replacing them, loosen the lid of the reservoir to make moving the pistons back easier.
    The rear caliper needs to be removed to access the pads. 2 bolts hold it on. Remember that you do not push that piston in, you turn it clockwise ONLY. If you have Bajaron's nifty tool, that's easy, otherwise, you can use a needle nose pliers in the 2 recesses in the piston.
    May 2019
    Port St. Lucie, Florida
    Quote Originally Posted by Poasttown View Post
    Thanks
    Poasttown
    I'm with you. Those videos help me, for sure.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by carsong View Post
    I can't count the times YouTube saved my fat. The best was when I had to rewire a 4-way switch (that's 3 switches controlling the same thing) and all the wires were black.
    Active Member ChicagoSpyder's Avatar
    Apr 2019
    Chicago
    Thanks
    Poasttown
    Smoaks does the brakes on an RT, should be the same or similar on an F3.
    2018 F3 Limited , Black/Chrome
