Results 1 to 5 of 5
    Jun 2021
    UK
    Default Lengths of brake linkage rods
    I need to lower the brake pedal to make it easier to control the breaking in slow moving traffic ,however I do not know the shortest linkage.
    My current linkage is 12 inches long but do not know the measurements of any replacements available.
    It would be appreciated if somebody knows the masurements of the rods available as the catelogue only statrs -1 to + 4
    Help!
    Oct 2015
    Lynden, WA
    Default Lowered brake rod
    I have a #3 brake rod laying on my desk. It measures 16" center to center on the holes in clevis ends. I changed to a #4 to fit my floor boards.
    Check out https://www.rattlebars.com/spyder/spyder.html for instruction to lower a standard brake pedal position.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2021
    UK
    I am trying to purchase a linkage rod about 10.5 inches long , rather than increasing the height of the rubber foot peg , but cannot determine the type available from BRP
    Mar 2013
    Marion, Arkansas
    Lamonster Garage has these that will lower the brake pedal
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Feb 2019
    Portland, Oregon
    Here is a free and easy solution that may do the job. Remove the rod and drill the same size hole just behind the original one in the front yoke. Then attach the brake pedal arm to it. It's worth a try.
