2021 Sea to Sky Trailer Harness
Installing a Trailer Hitch and Control Module (Hopkins 310-0041-559) on a Sea to Sky. The "Y" harness that connects to each taillight harness also has a single red plug in the harness. There is nothing in the install instructions about this wire. I'm guessing it's wanting power - because I'm getting nothing at the trailer plug - but haven't plugged in this mystery red wire.
Anyone installed this module on the new RT? Did you have to run a power line from the battery to the harness?
Joshua
2012 Victory Vision
2016 Spyder F3S
2019 Spyder RT Limited
Blazing Member
Your harness has a spade connector. Standing at the back looking ahead the bikes left side harness has a female spade connector taped to that harness . You really have to look for it and there’s no mention in the crappy instructions from BRP .
That's the red wire I was trying to figure out. Okay - this is helpful. And yeah, the crappy instructions from BRP had zero mention whatsoever. I'm guessing that's a power feed from the front that may run through a "trailer" specific fuse based on how the old models were wired.
THANK YOU VERY MUCH!
Joshua
2012 Victory Vision
2016 Spyder F3S
SpyderLovers Sponsor
Drove us nuts, too! Once you know, great!
Joe Meyer
Thanks again guys! That was definitely the missing piece. And it was indeed buried under tape. I also find it interesting the BRP setup doesn't turn on the trailer lights without the bike running. I've only done after market harnesses before - and they were all wired to be on with the key like the bike running lights. Just found it interesting - have to start the bike to check the lights.
Joshua
2012 Victory Vision
2016 Spyder F3S
