Results 1 to 20 of 20
    Active Member Bucketman's Avatar
    Jan 2015
    So WI
    Angry Good deal on rear tire replacement
    Had my rear tire replaced today with 12000 miles on my F3. I took the tire I bought (Kumho) to a dealer that said they would put that tire on. Got a call about an hour later saying that the brake pads were bad and needed replacement and said that they wouldn't charge me any more for labor since they had to take them off. The pads were $70 and I agreed to it but was a little concerned since we had a RT before that we put 25000 miles on without replacing pads. Oh well! The bike was completed in less than 2.5 hours. I was charged for 3 hours. Total bill at the dealer was $418.00 plus the Kumho I bought for $108 for a total of $526.00. If you would like to get this kind of deal, it was at Loves Park Motorsports in northern Il. Thank you for a job well done.
    P.S
    Tire was bald and service writer gave me the impression that I was hard on the bike and that was the cause of the brake wear. I thought I did pretty well getting 12000 miles on the original tire.
    Did you get the old pads back?
    Jan 2015
    So WI
    No, I did not. I should have asked for them.
    Dec 2018
    Elanora, Qld, Australia
    Quote Originally Posted by Bucketman View Post
    P.S
    Sounds like yet another guesser trying to frighten customers with junk talk. Both tyre and pad wear depend upon many possible situations, some often forgotten by replacement time. I'd be watchful with this workshop.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Jan 2015
    So WI
    Quote Originally Posted by RazzleH View Post
    You got it right on the money
    Apr 2020
    Tampabay
    I believe this may be a situation for the 20-21 models. I have a 2020 RT that had a 12000 mile service and new rear tire installed at Barneys Brooksville Florida. Service mgr. brought me the worn rear pads as I waited for the work to be completed. They were worn and needed replacing. We have six 2020 RTLs in our group and I have apprised the other owners of the group. All were amazed whereas I am very easy on brakes, I let the transmission do its thing to save brakes. I am now looking for “better” pads then stock to keep in case of premature wearing.
    We’re spending the summer in the Colorado Rockies where brakes are needed much more then home turf of Florida. We now have over 16000 miles on the bike and I’m fixing to inspect the pads very soon. $65.00 a pop on one set of rear pads every 12000 miles is a bit much.
    2020 RT , Custom Black Metallic
    Jan 2015
    So WI
    Quote Originally Posted by Bruita View Post
    Just curious, did you pay around $526 for your tire and brake service?
    P.S
    with #2,#3, #4, & #5 ..... Mike
    Aug 2012
    Central Coast, CA
    I can see it. I have a 2020 RTL and I just changed the rear tire and inspected the rear brake pads. Mine has about 11k on it, mostly highway miles and the pads are more than half way done. If most of your miles are city or back country roads with lots of braking and/or two up, then the pads will wear a lot more. Get the EBC pads and you should get better results.
    (Oh, and for the record, I replaced the OEM Kenda due to an upcoming trip and not because it was worn out, surprisingly enough.)
    2020 RTL SE6
    Active Member ChicagoSpyder's Avatar
    Chicago
    P.S
    I'm dropping off my machine next week, all three tires. I have less than 7,000 miles on mine and the rear Kenda is well into the wearbars, and I'm thinking my rear pads are going to be pretty worn, speed is always an expensive proposition
    2018 F3 Limited , Black/Chrome
    Oct 2020
    Arizona
    My 2018 RTL is looking better all the time!
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    So the thinking is the 20/21 models have different brakes that the prior models? Interesting.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Quote Originally Posted by robtdonna View Post
    No, not 'new brakes' per se - it's more that they have different 'braking dynamics', which is putting more of the stopping effort onto the rear & so wearing those pads sooner.
    Oct 2020
    Arizona
    My 2018 RTL is looking better all the time! I removed the rear tire and took it to a Can Am dealer in Mesa, Az and they charged me $27.50 to mount and balance the General RT43 and they kept the worn out Kenda. I was a happy camper. Earlier I took the front wheels to Discount tire and they mounted my Federals.
    Quote Originally Posted by ChicagoSpyder View Post
    For my 2014 RT I went 30,000 mi. on my rear pads ( and yes they were Very worn, but not completely ) .... PS I ride very aggressive .....good luck .... Mike
    Durham,Maine
    Got a feeling you may do a lot more engine braking than most Mike, from what I am reading from other posts! When it comes time to replace pads I would go see Ron for a set of EBC's, they work great for me!!
    2012 RTL , Pearl
    Mar 2013
    On my 2020 RT I replaced my stock rear at 9000 miles as it had no tread left on half the tire. Brake pads looked good. I now have 20,000 miles and after reading this thread decided I better check them. The pads still look good!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Actually I'm opposed to engine braking, the only downshifting I do, is to stay in the Power Band in the twistie's. .... I just try to drive and anticipate when I need to go slower ..... & when I changed Brake Pads I used Ron's .... Mike
    Mar 2017
    Well, I'm in the 9000 mile group. Tire was showing cords (Kenda) and rear OEM pads were nearly gone, so much so that I had a heck of a time getting the rear piston started onto the threads!
    I'm not hard on bikes. OEM stuff is junk! Got EBC pads from Ron. Here is Ron's rear set after 24k-9k = 15k of even harder riding.
    Chicago
    Had Loves Park Motorsports do my tire swap last week, Quatracs up front and a Kumho AST in the rear. First I have to say the service was professional and the labor for the tire mounting, balancing, and inspecting my air suspension came in at three hours which I thought was very fair. They set the front tires at 15 PSI and the rear at 28 PSI.
    I took the long way home last Friday from the dealer and put 210 satisfied miles on.
