Results 1 to 5 of 5
    Nov 2018
    Lisbon, Portugal
    Default Brake light switch mechanism sticking
    Just noticed yesterday when I parked the F3 the brake light was on.
    Seems it's not the switch but rather the mechanism that is sticking sometimes. Anything I should lubricate to avoid this?
    Thanks.
    2018 F3S , Monolith Black Satin
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by MakoShark2 View Post
    Thanks.
    Check the return spring (should there be one) as well. Perhaps it is too weak to pull the pedal and activate the brake light switch.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    In order to help the OE spring pull the pedal up so that it turns the brakelight switch off properly, many have simply added one of these...
    Nov 2018
    Lisbon, Portugal
    I don't think there is any return spring for the F3 it seems it might be the switch failling...
    Durham,Maine
    If it's not the switch, and you don't find a return spring on the brake linkage, that don't mean you can't put one on there some where! Possibly a good cleaning under there and a little lube on all the linkages and a switch adjustment is in order! good luck check it out! Let us know what you found!
    2012 RTL , Pearl
