Any suggestions on where to get a Fog light kit?
I have looked on the web, put have not found a complete fog light kit for my 2014 rt-s
any suggestion, thanks
Strange, I have a '14 RT-S SE6 that came with fog lights. I believe but am not certain that fog lights did not come on the '14 basic RT as in the operator's guide they are listed as an option package. If you look at pg 25 of your op guide you will see this. If you don't have a switch in the rightmost slot of the switch cluster you have a basic RT. I suspect your Spyder may be wired for fog lights but you will have to purchase a complete kit and from the parts listing I am not able to tell exactly which parts you will require by PN.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
2014 RT-S version came with fog lights. Not on the basic RT's.
Thanks for confirming.
Cognac 2014 RT-S
its a standard, thanks all
To find the parts you need, go to this web page, http://epc.brp.com/Index.aspx?lang=E...0-c3e26b480bfb, select Can-Am On-Road, select 2014 RT SE or SM, doesn't matter, and select Fiche 10- Electrical System Beam 20Y1401d, and you will see some of the parts you need. Unfortunately, the fiche does not include a PN for the complete L and R fog light assembly. A BRP dealership guy maybe able to help you but the job might become quite pricey. I know nothing about the Lamonster Garage product.
Cognac 2014 RT-S
