Results 1 to 19 of 19
    Dec 2015
    Oakley Utah
    Default I keep getting this message when I try to post pictures ... never had this problem b4
    Obviously, I can post pics elsewhere, but not on this thread (see #22) https://www.spyderlovers.com/forums/...19#post1585819
    2014 RTL Platinum
    That's odd, but I see what you mean?!? Have you tried using 'Manage attachments' instead of 'Insert Image'?? Or vice versa??
    Dec 2015
    Oakley Utah
    No. What is that?
    2014 RTL Platinum
    Bearing in mind that this is WAAAYYY harder to type out than it is actually to do....
    Click on 'Reply to Thread' or 'Post Quick Reply' then 'Go Advanced' - once you get the 'Reply to Thread' screen up (or after you've typed your text in), scroll down PAST the text field until you see 'Additional Options'. The first block in that will be 'Miscellaneous Options:' but you want the SECOND, which will be 'Attachments' - in there you'll see a button that is labelled 'Manage Attachments', click on that. That'll open a new 'Manage Attachments' screen that has a bunch of options for choosing files from your computer or from a website - when you select 'choose file', it'll ask where you want to get it from, your camera, cam-corde, files, etc - select one, drill down to find the pic you want, select the pic, then Done, & once its address/label is showing in the space alongside the 'choose file' button, click on 'upload file' which will be in the bottom left of that space. It'll take a bit of time to upload, and once it has, the address label will disappear from where it was but appear down in the THIRD block on that screen, the one labelled 'Current Attachments' - Once it's there, you can select another file via the second 'choose file' button in the list & then repeat all the other steps, but effectively once their address label is in the 'Current Attachment' field you can go back to your 'Post Reply' screen & submit the post!
    The pic/s will appear as thumbnails in your post, but in most cases 'Manage Attachments' will do the bulk of any re-sizing required and it'll often do the re-orientation too. Plus, when you click on the thumbnail, if the original image is of sufficient resolution, then even if it's small, your viewer can expand it on their screen to make it large enough to view clearly in a way that you often can't with 'Inserted Images'!
    Not sure it'll help with any problem that causes that particular message to appear (don't often see that one?!) but it works in many cases where 'Insert Image' fails, so I reckon it's probably worth a shot!
    Dec 2015
    Oakley Utah
    Thanks Peter. I'll give it a go.
    2014 RTL Platinum
    Jun 2017
    Rapid City, SD
    I had the same problem. Will try again with those instructions. Nope, 413 request entity too large
    HE>I
    2017 RT , Asphalt Grey
    Dec 2015
    Oakley Utah
    When I click on Manage Attachments, I get the same message and can't proceed further.
    2014 RTL Platinum
    I'll send it on up the line...
    Aug 2019
    Stoughton, WI
    Agreed ... I haven't been able to post photos in awhile
    2022 RT Sea To Sky
    Server Admin AnthonyG's Avatar
    mi
    Please try to post images as normal.
    There was an update to the server, this issue should be resolved.
    2018 F3 , Red
    I am getting the same thing. Doesn't matter if I use the 'Image' icon or the Manage Attachments option. Different error messages. But both tell me I do not have permission to post pictures. I hope they get this fixed.
    Jun 2017
    Rapid City, SD
    Looks like it’s working now.
    HE>I
    Jun 2017
    Rapid City, SD
    I couldn’t go back and add pics to old posts but it seems to be working with new ones?
    HE>I
    Dec 2015
    Oakley Utah
    Quote Originally Posted by RapidSpyder View Post
    Exactly
    2014 RTL Platinum
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    Looks like it's working again for me.
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    mi
    Try now with editing old posts & adding an image.
    2018 F3 , Red
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by AnthonyG View Post
    Yea it works, you da man
    HE>I
    Mar 2015
    forrest above Reno, Nv
    . Works now --------- Well almost--------
    2014 RTS , Circuit Yellow
