Results 1 to 5 of 5
Thread: Oil Change F3T
    Nov 2017
    Western Australia
    Default Oil Change F3T
    Getting mixed messages regarding oil drain plugs.
    What are the tools required to remove trans and engine drain plugs ?
    Jul 2014
    Mint Hill, NC
    Crankcase plug is T45 Torx, clutch cover, aka transmission, 6mm Allen.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2017
    Durham,Maine
    I had to ALL WAYS look at the hole to remember witch was witch! Now I just put a wrench on them, got a set of gold plugs from Lamonster!
    2012 RTL , Pearl
    Aug 2016
    Nashville, GA
    Get the Gold pugs as mentioned above, and you will like that a lot better. You use a set of sockets and a ratchet to take them out and it is a lot easier!
    Nov 2017
    Western Australia
    Thanks for the info. Oil change coming up, I'll try and get gold plugs for the next one.
