What size torque wrenches are needed for working on 2020 Spyder RT Ltd?
What size torque wrenchs needed for working on 2020 Spyder RT Limited? Sprocket, rear axle nut ect.?
Spyderjerry1, Get all three sizes 1/4", 3/8" & 1/2" drives. You will need then all eventually.
PMK, Any recommendations for a medium price one that's known to be accurate?
If you plan to torque the axle nut (which is 166 ft-lbs ) get one that is 24" long or more. Some torque wrenches are only about 16-17" long so that they will fit in a standard tool box drawer.
That extra 6-7" of leverage makes a big difference when you are torqueing those higher numbers, and especially if you don't have a lift and are trying to do it while sitting on your garage floor. DAMHIK.
As to brand, I have several inexpensive ones (Chinese?) that I bought from Amazon over the years and they all seem to be fairly accurate for the occasional jobs that I do.
For the rear axle nut I suggest a regular 1/2" torque wrench that will go up to 120 lb-ft used with a torque multiplier wrench such as this: https://www.amazon.com/Bentolin-Moto...s%2C230&sr=8-8
2014 Copper RTS
