Anyone know what Error code P2304 means?
Anyone know what this code means? Asking for a friend. He has a 2021 600...Search did not turn up anything.
Greg Kamer
USAF, 20 years, retired
2018 Can Am Spyder RT-Limited
Ozzie Ozzie Ozzie
Ignition Coil Primary Control Circuit high reading?? Faulty coil, harness, or poor electrical connection??
https://www.engine-codes.com/p2304.html
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Peter did you google that code or do you have a web site you go to?
Ozzie Ozzie Ozzie
Greg, i did a research in the service manual for Ryker 2019 and 2020 and could not find the fault code P2304 there.
Maybe this code is only used since the model 2021, so it could only be found in the service manual for models 2021 ... but i dont think so.
Could it be also possible, that there is some kind of confusion or misunderstanding and it is an other code (maybe the leading letter or one of the four numerals is different)?
Can you check this out once more?
Regards
Michael
From reading Peters info at #2 I'd ask myself if I hooked up any aftermarket electronics recently and go from there.
Did u ever find out what was wrong with it. I got the same code this morning on my Ryker.
