Results 1 to 4 of 4
    Mar 2018
    Oregon
    Default F3 driver backrest adjustment screw
    I was trying to adjust my backrest, and the screw was turning weird so I pulled it out and noticed that it is bent at the end.
    Is this normal or do I have to replace the screw?
    If I have to replace it, where should I go look for one?]
    Thank you!
    SPYDERGAL
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    You can probably find one at home depot or lowes.
    But just out of principal with how much BRP charges for that backrest I would be sending it back for an exchange just out of principal. They used some cheap stuff when making those backrest then charged us buku amounts of money for it.
    Mine started flopping around like a ragdoll on a stick just after a few hours of use. pretty much the same thing. Cheap a** hardware.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Mar 2017
    I built my own backrest for $180.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Rattlebars View Post
    Rattlebars,
    I'm guessing that when you use the Show Chrome backrest in the Ultimate seat backrest receiver, it just slides in and seats at the bottom? Any slop or free play? Thx
    2022 RT Sea To Sky
