Results 1 to 15 of 15
    Jun 2021
    Washington
    Default Garmin Zumo GPS where to mount?
    For those of you who've added the Zumo GPS, where did you decide to mount it?
    Also, how daunting is it to self-install? I'm not too mechanical and not confident to do the wiring correctly...though I assume asking the dealer to add it would be expensive!
    To clarify I have the 2021 Spyder RT Limited. The GPS is the Garmin Zumo XT.
    Last edited by ToddSims; 06-14-2021 at 01:39 PM. Reason: Adding clarity to my question.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Which Zumo and Spyder would help.
    My 396 (wish I had an XT) is mounted with a short RAM arm to a RAM ball mounted in one of the handlebar clamp bolt positions. The short arm connects to a RAM ball mount on the Garmin cradle.
    1976 RD400c
    Sep 2020
    Middletown, NJ
    It can be mounted on handlebars with RAM mount or using one of the mounts from the vendors here. The 12v power is located on the right side in front of the brake reservoir.
    2020 RT base , Chalk White
    Mar 2017
    Salisbury,NC
    i moved mine factory installed at handlebars, up to dash 2015 RTL. much safer i think, to only look at dash rather than lower on handlebars. they are posts here telling so, but not for 2020 / 2021 models. would be similar
    Feb 2017
    This past spring I mounted a Garmin 396 on my wife's 2021 Sea to Sky using, as I recall, Lamonster's bar center mounting bracket and some RAM bits I had in my parts box. It's the same mounting method as the Garmin 396 I mounted on my 2015 RT-S and it's served me well for quite a while.
    My "how to" for the 2021 RTL can be found here: https://www.spyderlovers.com/forums/...40#post1573540 Post #15 has the detailed description and photos. It might seem difficult but it isn't really complicated, it's mostly time consuming, I will readily confess I'm not an expert although I enjoy trying to do things myself and haven't (so far) had any unfortunate or fatal results on any of the three Spyders we've owned over the years.
    Jun 2021
    Washington
    Thanks Arion - I'll check it out!
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    I used a handlebar ram mount with a short extension and positioned my Garmin XT so it sits evenly over the center of the handlebars. It is perfect. I use a Kradellock to lock the GPS mount and RAM extension. The Kradellock is very well made and very secure. I run the power wire to the stock GPS plug on the right side. You can get an adapter from Lamonster that is plug and play for the stock GPS plug that gives you 2 accessory connections. Good luck!
    2021 RT Limited , Marsala Red/Black
    Mar 2013
    Maumelle, AR
    I installed the BRP mount.
    2020 RT Limited , Chalk
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    IMHO Lamonster´s mount is good cause the place it occupies is not used at all and does not disturb the view of the control panel.
    The screws coming with the mount does not fit throug the rubber parts on the xt contact part so I used the originals from Garmin but cutting them 7 mm aprox and adding some blue Loctite.
    2018 F3 Ltd. , Black/Dark
    May 2021
    Tennessee
    Quote Originally Posted by ToddSims View Post
    I used the Docking Station from Slingmods, it has 2 USB ports on left and cigarette plug on the right. Plugged into GPS accessory plug down on right side. Just make sure you tell them it's for a 21, there is an extra wire you use on the harness for reverse polarity. Run the GPS wire down along side the Docking station wire and use positaps to connect the gps wire to the harness from docking station.
    Aug 2022
    South Carolina
    Quote Originally Posted by Woodaddict View Post
    How did you route the power cable from the dash?
    Thanks,
    Mar 2021
    Ontario
    I used the mounting hardware that came with the XT. The dealer mounted it and wired it at no charge before I picked up the RTL. Seems to be a good location and I don’t have to look down.
    2022 Spyder RTL- dark trim
    1969 Plymouth Barracuda 340-S Fastback
    1969 Barracuda, 6.1 Hemi restomod, convertible
    1970 Plymouth Superbird, 440-6bbl
    Northern Kalifornia
    Word of caution. GPS units in cars have caused serious damage when left exposed to the sun.
    Apr 2020
    Lebanon ohio
    I use the handle bar clamp mount from lamonster put it right we're I whated it easy to install just one adjustment solid as a rock works great for me
    Danbury Connecticut
    I use the BRP mount with my Zumo XT.
    IBA #47122
    2020 RT Limited Asphalt Grey
