Results 1 to 18 of 18
Thread: Tire Pressure
    Active Member lois35's Avatar
    Sep 2015
    SC
    Spyder Tire Pressure
    Hello,
    I put two car tires on the front of the Spyder RT. Was wondering if you keep the same PSI as you would the original tires, which I think is around 20, or do you put the PSI as according to whats on the side of the tire that you put on it. Was just wondering.
    Thanks, Lois
    Quote Originally Posted by lois35 View Post
    Hello,
    Thanks, Lois
    The tire pressure on the sidewall is the MAXIMUM that the tire can be used at.... Peter and I have learned ( from science ) that any Auto tire used on any Spyder works best at 15 to 17 psi Front and 18-19 psi rear.. Auto tires are constructed more robustly so higher Air pressures are not needed. ... good luck .... Mike
    Jul 2014
    Mint Hill, NC
    I weigh 180, ride solo almost all the time and run 15 in my Federal EVO front tires.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Oct 2020
    KS
    The manual for the RT calls for 28 rear. What is your experience with 18-19 rear? That is 10 lbs less. They recommend 20 on the fronts and I can understand the lower pressure there. I've been running 18 fronts but may go to the 15-17 you recommend. I have OEM rear tire and Q5s on the front. Just wondering about the rear tire pressure that much lower? Leaving on a 2,000 mile trip next week. Thnx.
    Feb 2017
    Quote Originally Posted by milryder View Post
    If I read Mike's post correctly he recommended 18-19 psi at the rear if using an auto tire. OEM rear tire pressures you mentioned are appropriate.
    Oct 2020
    KS
    Ok that makes sense.
    Dec 2013
    The OE Spec Kenda tires really NEED those recommended pressures - they are constructed in much the same way as any other Passenger car tire, only a fair bit lighter, so if you run much less than maybe a pound or so less than the recommended 28 psi in your rear Kenda, you WILL be compromising your tire and your safety as well as the safety of other road users!
    With the Passenger car tires you've fitted, you can run lower pressures up front because those tires don't need or want as much air inside them to work properly due to their stronger construction & higher load capability; but until/unless you toss the OE Spec Kenda on the rear & fit a car tire, you are going to need to run the recommended pressure back there! Some who still run a Kenda back there fall into the trap of running a lower pressure in an effort to reduce the rapid wear rate in the centre of the tread that's usually such a feature of the OE spec Kenda rear tires, but that only moves the load & stresses from the middle of the tire to the outer edges and the sidewalls - sidewalls that are already somewhat weaker & more flexible than those of most car tires, so that increases the heat generation and can compromise their integrity and ability to work properly & safely, risking catastrophic failure, especially if you are riding at high speeds/longer distances! So really, that's DEFINITELY NOT something you want to do when you are heading off on a long trip!
    So please, stick with the recommended pressures for the OE Spec Kenda tire/s while they are on your Spyder (or Ryker), and when you get rid of the Kendas and fit proper Passenger car tires onto the Passenger car rims that are fitted onto your Spyder/Ryker, ONLY THEN should you drop your tire pressures to those suggested in Mike's post #2
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    with Peter - it all depends on the type of tire you have ... Auto vs. Crapenda .... Mike
    Jul 2014
    Mint Hill, NC
    I run 20 on my General Altimax RT 43 215/60R 15.
    Cognac 2014 RT-S
    Jay try going down to 18 psi and then go on a bumpy road ( like washboard if you can find some ..... Mike
    Northern Kalifornia
    How many miles do you have on your OEM rear tire?
    Sep 2017
    INDIANA, USA
    Default Kenda Rear Tire
    I got about 14K on my crummy First OEM tire (a Kenda).
    I ran it with 25psi and mostly one up.
    Going to try and find a place that will install the tires of my choice.
    Hope all is well ..............with you.........
    ENJOY YOUR LIFE WITH A SPYDER
    Dec 2016
    southern Oregon
    I run car tires front & rear with 18lbs front and 28lbs rear. No issues.
    Quote Originally Posted by mhopkins2 View Post
    " no issues " .... 28lbs for an Auto tire is `10lbs. to high. I'm not guessing about this ... Tire science says it .... On a wet road your rear tire will LOSE traction much sooner than the fronts .... with any luck the " Nanny " will save your Butt. .... In the Dry 28 lbs. is giving you a very Harsh ride compared to what `18lbs. would give. ... good luck .... Mike
    Nov 2019
    Kansas
    So for the Kanines, I should run 28psi for the rear and 18psi in the front?
    Oct 2020
    KS
    Only have 3,000 on the rear OEM. Since my dealer won't install anything else, perhaps even Lamonster, I will wait to see the opinions on the K9s and probably go with that for the rear when the time comes.
    Northern Kalifornia
    The reason I asked was if you had 5K or 6K on your OEM rear tire you might not finish a 2K trip without having to replace your tire before your trip was over. My OEM tire was done gone at 7K and should have been replaced before that. They go away fast. With only 3K you should be good. Have a safe/fun trip.
    Oct 2020
    KS
    Nice to know, thanks.
