Why don't techs like car tires?
Twice in the last month a tech has indicated to me that the Q5s being car tires should not be on my '21 RT. One at Lamonster said only a unidirectional motorcycle tire should be on there. He said the car tires won't show wear and you'll keep them past useful life, etc. huh?
The service manager at my regular dealer noted on the 3K service report that I had car tires. It was circled on the service report. I asked about that and told him many experienced owners have not had good results with the OEM Kendas. He said well its just an internet thing, he'd heard of a cord separation, etc. I explained how many owners with years of experience and thousands of miles have made a credible argument for the car tires. Neither tech in my opinion offered any factual arguments against the Q5s or similar car tires.
Has anyone else run into this from dealers? With all the positive reports here why do techs/dealers not like them? I know some only sell and install OEMs but there seems to be some other underlying bias against car tires. Maybe it's liability for the dealer especially on warranty? I went to Q5s after a 1,000 mile and notice a positive difference.
It's the party line driven by the lawyers and because BRP cannot find another manufacturer that will produce decent tires at a reasonable price. Your retort to techs who spout the party line should be, "If owners are not supposed to use car tires why does BRP equip Spyders with J type automobile rims?"
otherwise be a vulgar brawl.
Cognac 2014 RT-S
An excellent point. An ingrained reflex by those who don't ride them and have a management/mfg canned response. Another case where the customer has later information than the dealer/tech, just like not knowing about the new front pulley or the idler, at least until the evidence is overwhelming. In the end it is somehow about money and lawyers.
In so many professions it seems the practitioners have sold their ____________ for the sake of the dollar. Sadly, the person you might be dealing with has just had it drilled into their heads so much that they can't see any other way.
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
That's the way a dealer SHOULD work.
2020 RTL SE6
It's always about the $$$$ one way or another.
I too am lucky enough to have a dealer that will install any tire you bring in. "Bring em and if they are the correct size we will install them. A little money coming in is better than no money coming in. We have installed a lot of car tires on Spyders and haven't had a complaint yet." I do my own work including mounting tires, but it's good to know I can have them mounted there if need be. When we were prepping for our trip to Nova Scotia I had too many things on my plate so I had them change the oil and filter and give the RT a once over. Cost me a whopping $167.
Some additional places have been drinking to much of the BRP "kool aid." Surprised to hear the part about Lamonster Garage. They put Federals on my bikes back in 2019. The last time around, they ONLY had K9's. I put on a rear, but held off on the fronts. Now, it looks like I may have to find another tire source.
Can you provide a list of the “many riders” that have cord separation? Never heard it yet and I know many that have thousands of miles in Kendas. Well taken care of tires will perform just fine.
UNBELEIVABLE amount of BS from the tech!!!! really, an uninformed and using personal beliefs tech actually
I'll start. Count me as one. The tires looked fine but the bike was UNRIDEABLE above 60 MPH. Scary, DANGEROUS..... Jim
Semper Fi
SpyderLovers Sponsor
Not all OEM Kendas fail. Just a disturbing number of them. Overall, they are junk. To call yourself a 'Tech' and not know this should be an embarrassment to you.
It's OK to be biased based upon fact and experience. But being biased in favor of the OEM Kendas is not rational or recommended. Take this simple test. Go out and look at how much weight it took to balance your OEM Kenda tire. Then look at at a wheel with a car tire mounted and compare the amount of weight there. You are likely to find a great deal of difference. This is a testimony to the build quality of a tire.
If you've had good luck with OEM Kenda tires. Then more power to you! Don't buy too many sets though. As your luck is sure to run out.
One thing I will say is that the new Kenda Kanines seem to be a worthy tire from all reports. Too early to call this one 'Good'. But it's getting great reports from people I trust.
Flamewinger, have another read of Milryders comment. You are getting two separate sentences mixed up. At no stage did Milryder write that there were “many riders” that have had cord separation. He said the dealer had heard of “a” cord separation. That may indeed be the reason that you have “never heard of it yet”.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Thanks Flamewinger, you are correct. I told the tech "many riders" with a lot of experience were using car tires. I haven't heard of any cord separations on any of the car tires, not sure about the Kendas. People here would know.
Depends on the condition of the tire. PSI, mounting, weights, etc. Just because one Kenda might have been mounted wrongly or lost a weight or whatever fails, doesn't mean they are crap!! People are finding they're great on 2 wheel motorcycles. https://ultimatemotorcycling.com/202...ns-rubber/amp/
I have over 40K miles on Kenda OEM's and they're great! I know many that find OEM Kenda's are working out and continue to use them.
As my OEM Kenda's wear out, I'm looking to get a Knine on the rear simply because I don't want the hassle of finding someone to mount a CT. Fronts, probably not a problem to find any decent tire dealer to mount something other than a Kenda.
Originally Posted by teninospyder
A while ago now, I asked my servicing dealer if, after I bought it and brought it to him, would he install the Q5 on the rear of our 2014 RTL during it's next annual service?
His response with no hesitation was "yes". I even volunteered to pay the difference to compensate for loss of the tire sale and he said "No need. We don't work that way. As long as the tire matches the rim we are OK."
Pray that he never shut's his doors!!!! I am jealous as all get out, wish I lived close to you, he would be my dealer!!!
I would add that in 2005 Kenda paid me 110 dollars each to remove the 5 crappy tires they supplied for a 5th wheel trailer we purchased. They did not get named china bombs for no reason.
Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
2020 Petrol Blue Metallic RTL
Yep…..that’s going to be my strategy on the new RT too, bikerbill. I have a local tyre fitter who can and will mount and balance aftermarket car tyres, but based on the reasonable feedback of others regarding the Kanines, and my bad knees, I’ll be getting my dealer to do the rear. I did replace the rear once, and while it is easy for some, for me, the constant up and down was a real pain (literally )
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
It's all about the money; Krapendas are dirt cheap for BRP to obtain. They wear out quickly so the dealers get to sell the same cheap tire sooner and make more money. Car tires cost less per mile and last three or four times as long so the dealer gets less frequent fees for changing them. I have an independent tire shop close by that will mount them just like any other tire shop. All I have to do is take them the wheel to mount what-ever tire I have purchased from them. If they don't handle the tire I want, they charge me $20 to mount what I bring from somewhere else.
Those who say " I can't" will always be right.
