Results 1 to 25 of 27
    Jun 2021
    South Carolina
    Default Sway bar - is this upgrade worth it?
    Can someone who has a bajaron sway bar kit on there spyder, tell me if this upgrade is worth it, being new to the spyder, iam looking at the best inprovements for it, thanks
    indpls in
    its the first upgrade we put on our new spyders
    Look at it this way, if Ron's sway bar wasn't worth it he wouldn't be selling as many as he is. FWIW, when I bought my Spyder I had the dealership install one as part of the OTD deal in which they also laser aligned the machine. Soon after taking possession I went looking for semis traveling the interstates around greater Charlotte where the speeds are routinely 70 or more. I found two semis barreling along with an open lane between them and intentionally pulled into the open lane and increased my speed so I would swiftly get through their blind spots. As I passed through by the nose of each truck I could feel lots of wind buffeting of my upper torso, perfectly normal, but the Spyder was completely unaffected, tracked straight through with no swaying. Send Ron an email and ask any questions you want and you will receive complete, thoughtful, no BS answers.
    Oct 2020
    KS
    When I wanted an sway bar upgrade at Lamonster they sold me on the Elka front shock upgrade vs the sway bar, at least to try that first. I was ready to add both. I have a '21 RT. They indicated I would get more benefit overall from the Elkas and in fact the added sway bar may detract a bit from the Elka benefit. Like JayBros I have run the interstate, trucks and wind, and found the RT very stable. On my half mile of gravel and some bumps I noticed right away a smoother ride but also at 70-80, in wind and hard cornering everything seems very controlled and stable. From what some say the 20 and 21 models may benefit less than earlier models from the sway bar. It would be nice to try each one at a time and then both.
    Jun 2021
    South Carolina
    thanks for the info, ordering one today
    Sep 2020
    Middletown, NJ
    If you search the forum for sway bar you'll find hours of reading threads re: worth the upgrade.
    I don't recall any nay-sayers for this upgrade. Sway bar, auto tires, and shocks dramatically change the Spyder into a very capable and stable machine.
    2020 RT base , Chalk White
    Feb 2018
    Florida
    I have the Baja Ron sway bar. It's really an anti-sway bar. Made a huge difference on my 2018 RT. A much more stable feel to the bike.
    Jan 2013
    W.NC
    On my 2012 RT, I installed a sway bar, didn't really notice any improvement. Installed Elkas and was a happy camper, made all the difference. On my 2019 RT I've done nothing, it rides great.
    Durham,Maine
    Quote Originally Posted by StillKickin View Post
    done both and loved them both as much!! Now come the tires!!!! As soon as I wear out my old ones!
    2012 RTL , Pearl
    Oct 2020
    Arizona
    I did not wait to wear out the Kendas, Federals on the front and General on the rear.
    1. Front tires
    2. Sway Bar
    3. Shock adjusters
    4. Rear tire
    With a few weeks between each.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Snoking1127 View Post
    Ditto here....almost. Ron's sway bar and front Federals. Those made a good ride even better. The rear will be a winter project or an impulse buy.
    Durham,Maine
    2012 RTL , Pearl
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I just replaced my stock sway bar links with Baja Ron's for my 2021 RT. What a difference just replacing the links makes.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Quickdraw View Post
    Imagine, if you will, how much more of an improvement the bar will make. If you ride aggressively, you will absolutely love the results. If you don't ride hard, then save your money.
    Aug 2019
    southwest oHIo
    We did the tires first (Vredestein Q5), then the BajaRon sway bar.
    The tires were a HUGE improvement. The sway bar was a bit more subtle, but after a day of riding at Maggie Valley, my wife said she was not as tired. That made it worth it.
    We don't corner as hard as most of the posters here appear to, but there is still some difference noted.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Mar 2020
    Omak, WA
    I'm just doing research and reading here before I make a purchase.
    I'm curious how much does this all cost ? Sway bar+Elka+tires.
    Do you have to change front and rear suspension to Elka ? TIA.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by pyuchem View Post
    Ron suggested to me to do one thing at a time; first car tires - WOW, then the sway bar - WOWIE WOW WOW! I'm stopping there, at least for now. I'm very pleased with the results. Thanks Ron.
    Sep 2020
    Middletown, NJ
    I did in this order.
    The sway bar ~300 delivered
    Elka front shocks ~ 775 delivered
    Car tires (3) ~300 delivered
    Elka rear shock ~675 delivered
    Jul 2020
    New Mexico
    I am the 3rd owner of my 2015 rts. How can I tell if my sway bar has been upgraded to a Baja Ron's already ?
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Transam87020 View Post
    If the links from the bar to the A-arm are black plastic, then they are OEM. If metal - usually a color - that's a Bajaron. Especially if the links have that name, or another supplier's name on them.
    May 2021
    Upstate NY State
    I don't ride aggressively. That's a big reason why I didn't go the distance to replace the stock bar. It's typically my wife on her Ryker and I follow behind her. Otherwise, I would have changed the bar as well. My ride is more for pleasure and not so much pushing it to extremes. This is what happens when you get old.
    Oct 2020
    KS
    From what I read here it can be worth it but improvement may also depend on year of RT as some reports on '20-21 models show minimum improvement with sway bar. I was going to add one to my '21 RT and Lamonster garage convinced me I would get more improvement from the Elka shocks. I was ready to add the sway bar but the difference with the Elkas is significant and I am medium to high aggressive. They said sway bar might detract from the Elka advantage. So far I don't see a need for upgrading sway bar. I understand the difference in bar and shocks but Elkas not only soak up rough roads but keep the Spyder flat in corners.
    I wouldn't discourage the sway bar but just saying Lamonster had another opinion at least for my model year. Definitely consider upgrading shocks in any case.
    Feb 2019
    Portland, Oregon
    Thanks for the heads up of what happens when I get old. But when will that be? I'm 84 and love to challenge the corners in our mountains here.
    May 2021
    Upstate NY State
    You're 84 but probably feel young. I'm not that old but feel 120 with my back issues and pinched psychotic nerve.
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by skip View Post
    . Yes
    2014 RTS , Circuit Yellow
