Results 1 to 6 of 6
    Apr 2021
    Ky
    Default 1 or 2 oil drain plugs
    I have the owners manual out, only mentioned one drain plug, watched several videos, some very painful. But I was under the impression there were 2 drain plugs for the motor. Or does the transmission use motor oil?
    Mar 2013
    There are two. One for the engine and one for the transmission. They both use the same oil. I pull the engine plug first as that has the most oil in it than the trans side.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    If you look at the BRP parts lists for the 1330 ACE engines look for the Fiche for the Clutch Cover as that's where the "transmission plug" is found. There are two item numbers, one for the Magnetic Drain Plug M12 X 1.5, PN 420241782, and the second for the Copper Washer, PN 420250640. The engine and transmission share the lubrication oil.
    Sep 2009
    La Valle, WI
    There are 2 drain plugs for the SE models (semi auto transmission). If you have a manual clutch. I believe there is only 1. Correct me if I'm wrong.
    2018 F3 Limited , Oxford Blue
    Houston
    Quote Originally Posted by JP58 View Post
    All Spyders, both manual and automatic have 2 drain plugs. The manual does not have a transmission hydraulic control module filter.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Bryant, Arkansas
    Be aware that even though they may look like the same size, they need different sockets/plugs
