Results 1 to 11 of 11
    Louisiana
    Default Where to find/buy the Rear Trunk Shock for a 2015 RT?
    Anyone know where to find the rear trunk shock for a 2015 RT. ??
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Tdugas View Post
    Where to find it on the bike or where to buy one?
    2014 RTL Platinum
    Go to this web site, http://epc.brp.com/Index.aspx?lang=E...d-7bea40125dbe, Select Can-Am On-Road, Select Year and Model RT, Select Fiche 09-Luggages, Click on Item 99. PN is 708300383, Name Gaz Shock. Price is not given but Cheap Cycle Parts lists it as $64.99 and it should be close to the BRP price.
    Mar 2017
    Salisbury,NC
    there is also threads here on replacing one and adding one on other side to help hold up lid. there are a few sites that can match number of shock. i just bought 2 1 - replace, 1 to put on other side from McMaster carr. let me see if i can find the post
    here is one
    https://www.spyderlovers.com/forums/...for-Gas-Struts
    mine are on back order for another 1.5 weeks
    Default Trunk strut
    First open the lid - it's the thing on the left ..... But, in case your question is where to buy one !!!! .... when mine wore out I just made a metal rod ( shaped to fit ) that is attached through the trunk lip and this holds the lid up... and much higher than the gas strut ever did .... cost $ .05 +/- ..... Mike
    INDIANA, USA
    Default Trunk Shock
    ...... with the post from 'Blue Knight'. (Post #5). Enjoy your Day. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Durham,Maine
    Quote Originally Posted by Woodaddict View Post
    here is one
    Mcmasters is a good place for struts, when the one under my seat got so weak I had to hold it up to gas up, I ordered one from there, price was right, came fast, and now it opens it self, I have to push down on the seat a little because the struts pushing up on the latch!
    2012 RTL , Pearl
    PA
    Everything you need is in this video. https://www.youtube.com/watch?v=Y4av0_tQvow&t=71s
    Louisiana
    Thanks to all who responded found what I needed, sorry it was where to purchase one .. thanks again
    The ones from McMaster's come in different lbs. sizes for the same lenght ..... which one did you get ???? .... Mike
    Linden, CA
    Autozone
