Does Your Ryker Idle Seem "Rough"
Even when fully warmed up and at operating temp, mine ('21 900) seems to idle rough. According to the MFD, my RPM's when stopped are swinging from 800-950, and my handlebars are vibrating. I realize that the 2021 Operator's Guide specifies the idle speed as 850 +/- 50 RPM for the 900.
Do you believe I have a mechanical problem? Should I take it in for service?
I don't think you have a problem. Mine idles like that...and I like it. :-)
My 2019 Rally model does the same thing. It is a function of the fore and aft rocking motion commensurate with a three-cylinder engine.
My 2021 900 does the exact same thing.
Normal, dont worry about it. Just enjoy the ride!!
It wants to be a HD!!! Ride on!!
Thanks everyone. I made a video and as I was doing so it hit me that the tachometer is using an algorithm that displays in increments of 50 RPM, e.g., an actual RPM of 799 could display as 750. I also noted that a couple of times the RPM hit 750. That's the cooling fan cutting off at the very beginning of the clip.
Its a racehorse in the gate. That vibrating is just your Ryker chomping at the bit to get out and rip it up.
Stop worrying and ride!
Ya, both my Rykers idle like that. Sometimes when waiting at a red light, I find myself reaching my hand onto the handlebar grip to steady it so I can get a better non-vibratory glance out of the rearview mirror.
Mine doesn't vibrate any more since I changed the rear view mirrors
