Results 1 to 9 of 9
    Jun 2021
    South Carolina
    Default belt alignment - is this normal or a problem?
    new to the forum, just picked up a 2014 rt sm6, still got the have a clutch after 50 years on two wheels, i noticed during inspection the belt is riding on one side of the front pully ? is this normal or a problem ?
    it had a new back tire on it, when i got it , thanks
    Oct 2011
    Kalamazoo, Mi
    Your belt should be off the inside of the rear sprocket the thickness of a credit card. If this is where it resides, the front sprocket will take care of itself. Does either inside or outside of the belt appear shiny and or frayed?
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Jun 2021
    South Carolina
    no belt looks good, but it is tight on rear pully, i tried a credit card. go no
    Quote Originally Posted by skip View Post
    IF it is TIGHT to the flange I would do a 1/4 turn and see what that does .... I have seen video's of the belt while driving forward at speeds of 10 to 75 mph ... it is constantly moving moving left to right .... not a lot but it does move ..... Mike
    Read pg. 131-132 of your operator's guide to see what belt alignment is supposed to look like. If you don't have a guide, go to this link, drill down to your year and model and save to your computer: https://www.operatorsguides.brp.com/...adster&type=og.
    May 2017
    Mesa, Arid-Zone-A
    And, make sure you check your belt positioning after rolling FORWARD several feet. The belt does change position A LOT when going in reverse. Good luck.....Jim
    Semper Fi
    Feb 2019
    Portland, Oregon
    Another belt consideration is the tension. Mfr recommendation is too high. Krikit readings should be 140, rear wheel off the floor - 160 on the floor.
    Jun 2021
    South Carolina
    thanks, i known it set high on the ground it rear 270 on krikit
    Jun 2021
    South Carolina
    thank you
