Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Jan 2021
    Arkansas
    Default I'm back at it
    After I nailed the sound I wanted in my tests, I put down the audio project for another project. Seemed like a good stopping point to pick right up at later. So I packed it all away until now as I am back at it. I got the front tweeter speakers with the bass filters installed. I have relocated the 2, small, single speaker amps to the front and they are mounted under the speaker housings on each side. They are mapped to the front mid-woofers - 1 each. They will be hidden by the plastic moldings when I reassemble the shell of the bike. The rear speakers are sitting on my work bench, but even with out them, the bike is incredibly loud and clear with just the front 4 speakers. For one of the rears, I finished the dremmell hole and grinded the stickout corner of one of the Kicker 10PS5250 5-1/4" to get it in the rear housing and it fits perfect. I am done for the week as I am headed out of town tomorrow.
    Next milestones are to finish the rear mounting of the speakers, run the wiring for the fullsize amp, then add the powered subwoofer. My wife is insisting on the frunk holding the main amp (rear speakers) and the amp/subwoofer (uses the pass-passthrough signal from the main amp.) I still have a lot of electrical to do. More to come.
  2. #27
    Mar 2021
    Arizona high country
    I have been an audio buff since the 60's. Everything from a cheap stereo to multi thousand dollars speakers plus equally expensive electronics. But have never done anything on a scooter. When on anything but around town I always wear a full face helmet so all of my music is piped into the helmet. If only doing a local ride I wear a half helmet and really not interested in listening to music. While I applaud you guys tenacity to improve the sound on the Spyder, I am glad I haven't gone down that rabbit hole. LOL
  3. #28
    May 2017
    Mesa, Arid-Zone-A
    You guys are talking about stuff that is WAY above my audio knowledge level. But, I will interject one thing learned some time ago when upgrading speakers on one of my bikes. The new and "better" speakers didn't produce desired results because of the limited size of the speaker box. I ended up removing some shroud blockage behind the speakers giving them a lot more air on the back side. They then began to preform like I wanted. (They were Polk Audio Marine speakers)..... Just my 2 cents..... Jim
    Semper Fi
  4. #29
    Jul 2021
    Camden County, South Jersey
    5.25 JBL speakers, will this work in 2021 RT limited, because the radio sucks...
    or what should i do? change all 6 speakers? add 4 external speakers? add amps? please help. because the radio sucks...
  5. #30
    May 2021
    TX
    Default Adding a amp to my 2015 can am spyder rt limited factory audio
    Blueknight, I was wanting to add a amp to my bike. I've already upgrading my front/rear speakers with infinity 5.25 (rear) and hertz 6.5 (front). now my question is could you please provide me some information as to how you went about connecting your amp to your audio and still able to control your music volume, etc through the handlebar control system. Your help is greatly appreciated.
  6. #31
    Quote Originally Posted by ENGINEER View Post
    You have a Spyder that has NEW instrument panel that has the Audio incorporated in it ..... So far the only person to solve the stereo issue has been " Joel The Biker " ..... It took Him awhile but He did it ... ..... Just a speaker swap will help but there are other issues ..... Mike
  7. #32
    Feb 2016
    I like the sound of my Akropovic, but it's heavily biased to the right side only. Sticking with the Cardo Packtalk Bold with 45 mm JBL's for all other sounds!!!!!
    2020 RT Limited , Marsala Red
  8. #33
    Quote Originally Posted by JSmooth View Post
    After swapping out the OEM speakers and using 2 ohm JBL's @ 5.25 in. for all Four .... My sound got 200% better both quality & volume .... And all this with the OEM radio ...No AMP ..... this was only possible on Spydwers up to 2017 in 2018 CanAm went a different route with the integrated instrument pod ..... Mike
  9. #34
    Jan 2021
    Arkansas
    Quote Originally Posted by mkess View Post
    UPDATE - I have gotten both 5.25" speakers in the rear pods finally. I did what most do. I dremmel'd the hole to be bigger and used a bench grinder to grind down the one corner that stuck out. I am moving on to wiring the fullsize amp in the frunk and route the wires to the rear speakers.
    But first, I am headed to Darlington for the race this weekend. But I do have to get this done by October for a motorcycle trip we have, so I hope to have everything (with or with out the sub) and it be stable. I'll tackle the sub after in a separate project if I can't deliver before October.
  10. #35
    Jan 2021
    Arkansas
    Done.
    Results: Sounds Incredible. Full range of sound. Incredibly clear (compared to stock). Bass guitars sound incredible.
    Issues: Heat can build up in the Frunk. - would love to receive ideas on mitigation strategy.
    Total Build Cost: around a 1,000 bucks. This doesn't include the SMD tool which I will keep for other audio project now that I am on a path to becoming an audiophile. Nor does it include various test speakers purchases which I will redeploy on other projects or just sell off.
    Final Config:
    Kept the stock Front Tweeters
    - I installed 600Hz bass blockers to clean up the sound. - Crutchfield Bass Blockers
    Kept the stock Front Mids
    - Installed 2 (1 per speaker) Rockford-Fosgate-PM100X1 and used these setting:
    - Set the pass filter 100Hz (available settings are 60,80,100Hz)
    - Set the ohms to 4 (available settings are 2 or 4 ohms). I measured all stock speakers to be around 3.6 ohms.
    Changed out the rear speakers to these Kicker 10PS5250 5-1/4" 2-way motorcycle speakers (2-ohm).
    - Speakers are bigger and required modification of the rear mounts. I ordered a set from Ebay from a wrecked 2019 RTL. I did not want to modify our originals. Bonus – they came with additional stock speakers so I guess I have spares.
    - These speaker are controlled by an amp in the frunk.
    Amp for rear speakers - Rockford Fosgate PM300X2
    - Converted rear speaker outs to rca and ran wires from back of bike to front.
    - In the same fabric-taped homemade harness, I ran the speaker outs from the amp to the rear speakers.
    - I tapped into the power wire of the USB port in the rear trunk for remote power wire for the amp. When the ignition is on, the USB charger has power. I use this wire to tell the amp to turn on since it is directly connected to the battery.
    Amp-powered subwoofer added to the Frunk - Sound Ordnance B-8PTD
    - Midway through the fabric-taped wire harness, I split off from the remote amp wire to a switch in the middle of the rocker switch panel. I inserted back into wire harness headed to the front. This wire controls the amp on the subwoofer. Now I can turn it on or off at will, but on only when ignition is on.
    - I also added a remote dial in the center storage compartment and injected that wire into the harness going to the frunk.
    NOTES
    - The big amp on the rear speakers is tuned way down. It is probably pushing 50 Watt RMS max to each of the 2 rear speakers – even though the amp is rated for 150 watts per channel. The overkill on the amp is to get the expanded tunning controls that don’t come on a smaller amp.
    - The stock speaker-outs from the radio are so low that both the big amp to the rear speakers and the powered subwoofer required the connection be wired to the rca low-level inputs instead of the high-level inputs. This should tell you something.
    - I used a D'Amore SMD DD-1+ to determine where distortion starts in the radio. Conveniently, you can set the volume on the radio at 12 o’clock on the main volume screen/home volume screen. I don’t know what position that is on the sub-menu volume screen but it equates to like 1:30 or 2 or something. My wife is instructed not to go higher.
    - Tuning the big amp for the amp built into the subwoofer are both tuned way down. the gain is nominal and the bass boost on both is set to 0. My goal was loud and clear, not loud as hell and shake the bike. The result has exceeded my expectations.
    Other parts list:
    - https://www.crutchfield.com/p_136XDC...LRAIC2-SW.html
    - https://www.crutchfield.com/p_142EXT...he-EXTAPE.html
    - https://www.crutchfield.com/p_142R12...s-12-foot.html
    - https://www.crutchfield.com/p_142R15...t.html?tp=1694
    - https://www.crutchfield.com/p_142PA8...iring-Kit.html
    - https://www.crutchfield.com/p_007CK1...ield-CK10.html
    I'll gather up some pictures and create a fresh post with this content at a later date. Cheers!
  11. #36
    Jan 2021
    Arkansas
    Default DONE (in pics)
    Visible through the air venting grill once the body plastic is installed. Marine grade so I would rather have it where it gets air and can also see the power on/off light.
    This is just a hasty, functional install of wires. I got it operational for the upcoming trip to TOTD, but I have already ordered new wires that are long enough for me to hide them where the come up from the bottom behind and/or beside the amps.
    Center button turns on/off the powered subwoofer. I doubt my wife will ever turn it off except to show someone the difference it makes.
    Subwoofer AMP potentiometer - Dial up or down the bass. My wife already says she'll probably always keep it at 11.
    The battery and charging system handle everything with no problem. She can idle with all her lights on, the stereo at full, do several engine starts, and when I put it on the charger, it goes to green in less than a minute. I observed some issues with heat build up in the frunk on one occasion, but by adjusting the fader on the radio to one notch off-of-center toward the front speakers, the drive was reduced just enough to bring the amp temp down tremendously. I can tell there is less sound from the rear speakers but my wife cannot.
    I would like to thank all the posters on here that gave me bits and pieces of my own puzzle - how to modify the rear speaker pods, that it is ok to use 2-ohm speakers (which I made even safer by having a high-quality amp in front of them), some speaker models to try (and not bother trying), and more. Cheers!
  12. #37
    PA
    I bet it sounds great, seriously! But not as good as my wife. My wife would never ride again if I said she lost the frunk space for an amp and power supply . Impressed with the follow through and work.
  13. #38
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Wmoater View Post
    I agree, I couldn't give up the frunk space unless I towed a trailer.
  14. #39
    Nov 2019
    Kansas
    Done.
    Final Config:
    NOTES
    Other parts list:
    I would pay you money to do this with my 18 F3L
  15. #40
    Aug 2020
    Edmonton, Alberta, Canada
    Great write up mkess.
    Good to see someone else going the distance on their audio system. Adding an amp is definitely a game changer on the sound quality and volume. I run 3 amps on my Harley.
    Good to hear the charging system holds up fine. I didn't have many doubts, but you don't know until you try.
    I'll be starting on my wife's 2016 RTS hopefully this week.
    I've done lots of Harley upgrades, but this will be the first Spyder
    It Sounds like you went the same route I was planning. Just went off the speaker leads to a Line level converter to RCAs into an amp, and off to the speakers.
    The amp I'll be using is the Stinger SPX 700 4 channel amp. It's a motorsports amp that works great on bikes. I've used them with great success on Harleys.
    I have Polk 5.25" MM1 speakers for both front and rear speakers that I can try out. Not sure if there is enough room but im hoping I can find a way to install a set of 6.5" Mmats coax sor Hertz SX165 SPL peakers in the front fairing using a 5.25" to 6.5" speaker adapter.
    Good to see you used the SMD DD1 to set up your gains. Great tool to have. I have one here as well.
    I see you were considering using a DSP. The new Ground Zero HKI mini is popular on Harleys. I've also used the Dayton 408, but it can cause some engine noise using RCAs, so most guys wire it in with high level inputs, which may not work if we have to use A Line level to RCAs.
    Wish me luck on my adventure, lol
    Rock on, and play it LOUD!
Tags for this Thread
