Results 1 to 4 of 4
    Jun 2020
    San Antonio, TX
    Default 2013 RTL cat delete - anyone making them?
    Was interested in a cat delete for my 2013 RTL. Seems like no one is making them any longer. For those that have one, does it make a big difference in heat reduction or increased power? Or, would I be wasting my money having one made? I have read the 1330 does much better with cat delete but not sure if it is the same for the 998.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Quote Originally Posted by Chiefburg View Post
    Well the CAT is a heat sink, so yes there will be less heat ..... The ONLY thing that will increase power is an ECU re-map .... go to MonsterFuel.com ..... Mike
    Idaho
    It's been 5 years since I had my 2013 RT with the 998 engine. I put a cat delete on it but as best as I can remember whatever improvement in performance there was, wasn't enough to warrant the cost. It did give it a little bit bit more throaty sound though! If I had to do it over again I would pass.
    2014 Copper RTS
