Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    May 2016
    Mansfield, Ohio
    I like the idea of using a hidden unchipped key that would allow you to unlock the storage compartment that hides a chipped key.
    2021 RT Limited , Deep Marsala Metallic (red)
  2. #27
    Jan 2021
    Oklahoma City
    A follow up question on un-chipped keys, will they unlock the frunk the same as the OEM key, ie pushing down on the key while in the ignition and turning towards the frunk icon?
    It seems they would since that is all mechanical as far as I know vs software/chip dependent like actual ignition procedure.
  3. #28
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Plarimer View Post
    Maybe I知 making a simple problem more complicated. I have been looking for a place to hide a spare key for my RT. After several evaluations I finally realized that on the right side of the dash I have a blank cover that pops off. I simply wrapped the key in a plastic bag slipped it in and put the cover back on. One thing I didn稚 think of until this morning Is will the programming from the spare key interfere with the programming of the key in the ignition. I知 not very good at explaining this but I hope you understand what I知 trying to ask. Thanks so much, Peter
    The Spyder key does not have a battery in it. So the range is extremely limited. I tested my 2013 ST and found the range is about 1.5 inches max. I assume yours will be the same. The chip is different but the technology is the same.
    2018 F3 LIMITED
  4. #29
    Jan 2021
    Monroe, la
    A cut standard key will unlock everything and will also turn the power on for everything but you cannot start the engine.
  5. #30
    Jul 2011
    Here is a picture of my unchipped key. JMA ZA 9P1. Don't have to grind the corners off.
    2018 F3 LIMITED
  6. #31
    Idaho
    Quote Originally Posted by Adventurer View Post
    Yes. You just need to make sure the head of the X270 is cut back to near the shape of the OEM key to allow it to go deep enough to turn to unlock.
    Just for the fun of it, I held my chipped key next to the X270 and turned on the ignition with the X270. The code was read from the OEM key and the Spyder started right up. Then I put the chip key in my pocket and drove away! Well, I didn't actually drive away, just pretended I did!
    2014 Copper RTS
  7. #32
    May 2016
    Mansfield, Ohio
    Quote Originally Posted by Donbmw View Post
    Oh-Oh, I was hoping that an unchipped key would not turn on the dash. Therefore, I assume you could then release the electric parking brake and roll the Spyder away!!
  8. #33
    Idaho
    Quote Originally Posted by knobby View Post
    I never gave it any thought but you are correct. That's why even the unchipped key needs to be kept where an unscrupulous passerby won't likely find it.
    But the parking brake being set isn't a real deterrent anyway. Think of all the discussions here about how to release the PB when the PB motor doesn't work!
    2014 Copper RTS
