Results 1 to 7 of 7
    Feb 2013
    Rockville, MD
    Default Can I Add a USB to 2014 RTL without using T taps?
    Has anyone successfully added a USB port to the dash switches or elsewhere without using T taps - via accessory. How was it wired?
    Last edited by Peter Aawen; 06-05-2021 at 03:11 AM. Reason: Removed Prefix - this is a 'How do I?' Question not a 'How to:' DIY explanation....
    Jul 2014
    Mint Hill, NC
    One option is to eliminate the analog fuel and temperature gauges and rely on the digital display. Some folks replace the temp gauge with a volt meter and you could put a USB receptacle in the left side. The diameter is 52 mm. Sorry, don't know squat about the wiring but I'm sure some folks can advise and I believe you won't have to use T taps but can plug directly into existing wiring that powered the analog gauges.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2013
    Rockville, MD
    Was hoping to keep those gauges. Perhaps someone has another option. Thanks for the ideas.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Smokin' Al View Post
    What do you mean about not using T taps?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    The easiest place to run wires to the dashboard area is the speaker grilles.
    2014 RTL Platinum
    Idaho
    All four of the switches on the dash, even if there is no switch installed, have a connector underneath that have both switched 12v and ground connections. I think you can just plug a spade connector into them.
    2014 Copper RTS
    Feb 2013
    Rockville, MD
    Didn't know that - I'll explore that option. Thanks
