Results 1 to 8 of 8
    Mar 2021
    MD
    Default Driver seat - can't get it back on! Help!?!
    BE14FF09-0F30-47AC-B9FC-D171AFC9B640.jpegI may have made a bone headed move. I removed the original driver’s seat to help me with another install. Now I can’t get the dang seat back on. The back foam tabs keep popping out. Any suggestions? Thanks.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I will try to explain how I have done mine. You have the long bolts that go through and starting threading into the nut that keeps slipping. I put a piece of painters tape on the outside of the nut to hold it in place and slowly started threading the bolt. I've done this a bout 3-4 times now. Works good. Hope this helps.
    Mar 2021
    MD
    Thanks. I’ve added a picture. I don’t believe I need to get to any screws, unless I have to take the entire seat off.
    Dec 2020
    Mesa, AZ
    If memory serves me, the service manual says to squeeze the tabs using the large foldable paper clips.
    Jun 2018
    Pahrump NV
    Sorry, I misunderstood what you were trying to do.
    Sep 2017
    Durham,Maine
    Quote Originally Posted by hihosilver28 View Post
    From that picture it looks like the trails of that seat have to be in the slots below the tabs!! So the only way that is going to happen is remove the pad enough so you can get them started in those rails! The seat must come apart from the front and slide forward to take apart!! Good luck! The seats got to come off and be reinstalled in the seat pan!
    2012 RTL , Pearl
    Dec 2020
    IL
    If you have the max mount the paper clip method won't work. The only way to get that back on is to split the clamshell, raise it 5 inches and pop the seat on. It sounds like a lot of work but it's not. Job can be completed in 45 min. 15 min to open shell, 15 for seat and 15 to put it back together. You already spent more time trying to figure it out lol.
    Mar 2021
    MD
    Thanks. The clamshell was the way to go. It was more work since I really didn't know what I was doing. I did watch Bill R's video, but things are never as easy as it looks in the video. I've learned my lesson on this one!
Tags for this Thread
