Need a Trouble code reset on 2010 RT - how? Limp Mode likely?
Other than going to the dealership, Is there any way to reset trouble codes on a 2010 RT?
If there is Actually something wrong it won't clear without correcting that issue ..... however the Spyder computers are very very sensitive and will show " non problem codes " if taking the key out of the ignition and moving it 2 ft from the ignition and then re-place and start doesn't clear it ( it should ) .... dis-connect the battery cables and touch them together - then re-connect (using Star washers on terminals ) .... this should clear any non problem codes ..... good luck ... Mike
I’ll give that a try. I got p0251 and p0252 from one day to the next
Ozzie Ozzie Ozzie
Both of those codes relate to the Injector Fuel Pump Metering exceeding it's allowable parameters, so they might not clear too easily.... or it could just be that you've got some dodgy fuel in there!
Sorry, p0551 and p0552, must be getting old 😖
Ozzie Ozzie Ozzie
Reason: Link info
How old is your battery? It may be too weak to properly operate the DPS.
Will codes P0551 & P0552 cause Limp Mode?
Will driving with P0551 & P0552 codes cause the bike to go into limp mode? I’m 50 miles from the dealership.
