Results 1 to 15 of 15
    Aug 2019
    Minnesota
    Default Hesitation from stop
    Greetings
    I notice that pulling away from a stop, there is a slight hesitation, like a clutch is not fully engaged. Then it locks up and everything is fine. I know it is a semi-automatic, that is just my best description.
    It does it most of the time. I can minimize it if I am light on the throttle.
    2019 F3T
    Is this normal?
    Thank you for any help.
    ba
    2019 F3-T Liquid Titanium
    “we are all products of those to whom we have chosen to listen”
    2019 F3T , titanium
    Durham,Maine
    When was your last oil change, did you do it yourself? What did you use for oil if you did do it? Have you checked your oil level?
    2012 RTL , Pearl
    Aug 2012
    Central Coast, CA
    It'll do it if it's not fully warmed up to normal operating temperatures.
    2020 RTL SE6
    Aug 2019
    Minnesota
    10 months ago
    No, dealer
    BRP semi-synthetic
    Level middle of the range
    Amber color and clear
    ba
    2019 F3T , titanium
    Aug 2019
    Minnesota
    Quote Originally Posted by KX5062 View Post
    It'll do it if it's fully warmed up to normal operating temperatures.
    KX, have you experienced this too?
    The latest experience with this was a ride around town, operating temp was the temp gauge in the center top.
    ba
    2019 F3T , titanium
    Durham,Maine
    Quote Originally Posted by arachnyd View Post
    10 months ago
    No, dealer
    BRP semi-synthetic
    ba
    You do the filter also?
    2012 RTL , Pearl
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    First thing, that pops in my mind, is the hillhold function, this works to prevent from rolling back, when on a incline, It will disengage after a second or so.
    Maybe yours is just to tight.
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Dec 2018
    Elanora, Qld, Australia
    My new 2020 F3L also does this hesitation from cold start until the engine has warmed up a little. Such is Not an oil level cause/solution, but rather a simple fuel, engine temp and air temperature combination situation. The oil will be circulating from almost the moment the engine turns over, regardless of where on the dip stick the level is (even from below the lower level mark). All quite normal across the board for all engines from cold start.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Nov 2019
    Kansas
    When I first start mine, when I give it throttle, the engine goes all over the place as I wait for it to engage. I need it running for 5 minutes or so before all that ridiculousness goes away. Once that happens, it wont happen again until I start it cold again.
    My old 2016 F3T did the same thing. Drives me nuts, but it is what it is.
    Aug 2019
    Minnesota
    Yes
    ba
    2019 F3T , titanium
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Bought my 2104 RT LE just over two months ago and throttle hesitation from a stop is one of the few issues with my Spyder I find annoying. Once moving no issues. Seems to be common from what I have read. Could put an aftermarket product on to compensate, or have the ECU mod by Monster Fuel Injection. Depends on how annoying it is to you, and how much do you want to spend to get rid of it.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Jun 2011
    Alamogordo, NM
    A question that I don't have an answer to as don't have a Spyder.......Yet. What actuates the clutch, is it centrifugal force from the engines RPM, I know that the clutch disengages at idle. Or could it be hydraulically actuated, thus a very sluggish engagement when a cold newly started engine.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Mar 2017
    Hill hold? My '16 T will roll back or forward on an incline in 1st without the brake. Best to start the bike then put on your gear then get on the bike and ride. Should be warm enough.
    Aug 2012
    Central Coast, CA
    10 months ago
    No, dealer
    BRP semi-synthetic
    ba
    I had a typo in my reply and meant to say that mine will do it when it's cold and NOT up to operating temperature. My 14 was worse than my 2020, and the 14 had a slight stumble off of idle if you wacked the throttle too hard. I had the shop look at it at the time under warranty and they found nothing wrong, so I just made sure to not hit the throttle too hard, especially when not fully warmed up.
    2020 RTL SE6
    Jan 2021
    Oklahoma City
    My 2021 RTL also has a flat spot that is noticeable when taking off from a dead stop. It’s worse when it hasn’t fully warmed up but it’s still there even after reaching operating temp. It’s just noticeable enough to be annoying.
