Results 1 to 7 of 7
    Apr 2021
    OH
    Spyder Any Adapters - 4 pin square to 4 pin flat for trailer hitch?
    Bought the BRP trailer hitch.jpg4 pin plug.jpg it came with a 4 pin square. Anyone aware of a connection to make it a flat 4 connector?
    2014 RTS SE6 , Black
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Mooserd View Post
    I think LaMonster has what you need. http://www.lamonstergarage.com/can-a...ter-lamonster/
    2019 F3L , Covid Blue
    Sep 2014
    USA
    Cut the flat four in two and tape (or heat shrink tube) one half on top of the other. It'll then fit the square four. I haven't done this myself but others here on the forum have.
    Dec 2015
    Oakley Utah
    I've never tried that but it sounds workable.
    2014 RTL Platinum
    Oct 2015
    Lynden, WA
    I did the cut and tape of the Flat 4 to make a
    Square 4 for the hitch on my previous ST.
    It worked without a problem.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jul 2011
    Mitchell, Ontario, Canada
    Buying the adapter from Lamont is a good option. Does not alter the trailer or Spyder. So the trailer can be towed by any other vehicle with a flat 4 plug.
    Cutting the flat 4 in half should work but limits what you can tow with.
    I have in seen in auto parts stores a 1 foot long extension cable with a flat 4 on both ends. Just thinking that cutting the male end of that in half and making a square 4 out of it. That would be cheap and the trailer can still be towed by another vehicle.
