Results 1 to 18 of 18
    Nov 2017
    Gaithersburg, MD
    Spyder 12V trunk no power
    Hi
    the 12 V at the trunk has no power (RTL 2017). Any suggestions for a troubleshoot?
    MUch appreciated
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Hi look at the fuse #6 in the frunk inside the left side fuse panel. It only has power with key on in this position. If you want power all the time switch the fuse to #7 position.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Nov 2017
    Gaithersburg, MD
    Thank you. I tried this. Still no power. Do you think any connection would have gotten lost/losse?
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    key must be on and motor running
    richie spyder
    Dec 2015
    Oakley Utah
    Quote Originally Posted by BriteSpydie View Post
    If the fuse is good, then it seems there must be a problem in the wiring between fuse box and trunk receptacle, yes.
    Have you had any work done to the bike since the last time you know the receptacle had power to it?
    2014 RTL Platinum
    Nov 2017
    Gaithersburg, MD
    Also, one quick question Is there a separate fuse for the trunk 12V? Thanks a lot.
    Nov 2017
    Gaithersburg, MD
    Only an oil change was done. Thanks a lot for your kind response.
    Dec 2015
    Oakley Utah
    The fuse that is located in position F6 or F7 (depending on whether or not you want the trunk 12v receptacle to be powered even with the ignition off) feeds only that trunk 12v circuit, I believe. If the fuse is not blown and you have the ignition switched on, then there should be power there regardless of which fuse block position it is in. Otherwise there is another problem.
    Let me ask you this; how do you know there is no power at that receptacle? Did you test it with a meter or what?
    2014 RTL Platinum
    Nov 2017
    Gaithersburg, MD
    Oh. Is the fuse at F6 or F7 only for the trunk 12V? Maybe should I change the fuse and check? Thanks a lot for your kind help. I appreciate it much.
    Dec 2015
    Oakley Utah
    That should not have impacted any wiring.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Yes, it's only for the accessory circuit, the one in the trunk. Did you pull it out to check to see if it's blown?
    2014 RTL Platinum
    Nov 2017
    Gaithersburg, MD
    I will do this now and revert to you. Thanks a lot.
    Nov 2017
    Gaithersburg, MD
    Hi UtahPete, It worked. The fuse was blown off. I replaced it with a spare and it is working now. Thank you so much.
    Dec 2015
    Oakley Utah
    You're welcome. And, congratulations on fixing it yourself.
    2014 RTL Platinum
    Nov 2017
    Gaithersburg, MD
    Thank you. I do not know why it blew off though. Now it is fixed. Have a great evening.
    Dec 2015
    Oakley Utah
    What did you plug into it when it blew?
    Some accessories can draw more current than the circuit wiring is designed to handle, causing the fuse to blow.
    2014 RTL Platinum
    Nov 2017
    Gaithersburg, MD
    I put in a Bluetooth receiver. It worked well. that was the last time I used it.
    FYI, the F6 & F7 fuse positions feed the frunk accessory outlet, if you have one, as well as the trunk accessory outlet.
