Results 1 to 8 of 8
    May 2020
    Boston
    Default LED Tail/Brake Light replacements for 2019 F3?
    Hi,
    I want to replace my OEM brake lightbulbs with much brighter LED bulbs. I've been researching but, I can't seem to find an LED replacement for my OEM bulbs that I'm 100% sure will work on my 2019 F3.
    Any recommendations or links will be appreciated.
    Thank you
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Try these, I think you will like them.
    https://www.superbrightleds.com/vehi...3274&year=2019
    Al in Kazoo
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Feb 2019
    Portland, Oregon
    This should work. Note that the latching pins are at 120*, not 180*. There are videos to undo hyper flash, should they do that.
    https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    May 2020
    Boston
    perfect! Thank you
    Aug 2019
    Stoughton, WI
    You will need to add a resister to avoid hyper flash.
    2022 RT Sea To Sky
    May 2020
    Boston
    Is that needed for any LED bulb?
    Aug 2019
    Stoughton, WI
    Yup . To avoid hyper flash
    2022 RT Sea To Sky
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    why can't they make a flasher that is designed to work with LED bulbs, or make a resistor that just goes in-between the bulb and the socket, so as to make it all plug and play.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
