Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 176 to 200 of 233
  1. #176
    Dec 2020
    Hartwell, Ga
    Post pics of the old thermostat, that could help explain things.
  2. #177
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by bluewoo View Post
    This link shows #2 flat head screw? .....
    That screw holds the cooling pump DRIVING gear to the cam shaft...........
    To get the the old thermostat I have to cut up the old pump which I'll probably do
    Lew L
    2014 RTS , Circuit Yellow
  3. #178
    Mar 2015
    K80---- you're the winner!!!! I cut out the old thermostat and the "Mystery plug" is part of it. The thermostat is NOT made to come out!! I used a dremel saw and cut the locking tabs as I'll NEVER use the old water pump again. the plug helps center a spring under the thermostat. The mystery is how it got loose????
    Now to put it all back together--------------
    EDIT: old thermostat worked. mystery plug stopped it from opening to far. Could see wear marks in the right spots and right sizes to stop thermostat expansion. I don't know how it got loose, It's kinda locked in place by a plate and spring.
  4. #179
    Sep 2014
    USA
    Alright. Solved that mistory..
    So the leak has stopped?
  5. #180
    Oct 2015
    Lynden, WA
    Thumbs up RT Overheating
    Lew, Great detective work and documentation.
    We can all learn from your evaluation and explanation.
    Thank You.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  6. #181
    Durham,Maine
    Put it back together again and ride the thing!!!!!!!!!
    2012 RTL , Pearl
  7. #182
    Dec 2020
    Hartwell, Ga
    Glad you found the problem. I've saw many thermostats come apart over the years.
  8. #183
    Sep 2014
    USA
    Must be a odd thermostat versus what I am use to??
  9. #184
    Mar 2015
    I sure wish I could. I did put it all together with high hopes---------- and it's leaking out the bottom the the pump housing
  10. #185
    Mar 2015
    Yes---- three extra ( and loose, not attached to the actual stat) pieces including the mystery plug that caused me grief.
  11. #186
    Durham,Maine
    Is it cracked??
    2012 RTL , Pearl
  12. #187
    Sep 2014
    USA
    Is the gasket shifting while you are installing the pump? O ring is still got too?
  13. #188
    Mar 2015
    Although there is not much room there the pump goes straight in the last 3/8". I'm going to rent a radiator pressure tester from the local auto parts store--- that will tell me more. I have even read about cracked coolant tanks???
  14. #189
    Mar 2015
    Is it cracked??
    The pump housing is plastic BUT very tough. The 5 bolts that hold it in place have a sleeve to stop any cracking and I do use a fairly new in.lb. torque wrench to the correct specs and tightening order. It's a 2 stage torquing like cylinder heads ,ect.
  15. #190
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lew L View Post
    Wouldn't those causes be evidenced by leaked coolant?
    2014 RTL Platinum
  16. #191
    Sep 2014
    USA
    Bring the cap with you when you borrow the tester. This way you know you have the right test cap in the tester. They say 15 PSI to test.
    Is it coming from the pump or are you not sure yet?
  17. #192
    Mar 2015
    There are 3 hoses that come out of the coolant tank and 2 are well hidden. I'll top up the tank and pressurize it to see if there is a crack . It is a process of elimination before I pull the pump again.
  18. #193
    Durham,Maine
    You should know for sure where it's coming from before you take it apart again. That way you know what your fighting!
    2012 RTL , Pearl
  19. #194
    Sep 2014
    USA
    Yep one out to the radiators one hose back from the radiator and the tank hose.
  20. #195
    Dec 2015
    Oakley Utah
    How is this project going, Lew?
    2014 RTL Platinum
  21. #196
    Sep 2014
    USA
    Mar 2015
    R and R the pump again and it still leaked when pressurized to just a few psi. I'm biting the bullet and its going to the local dealer. I hate giving in but I was getting too good at removing the pump and bathing myself in antifreeze ( even with the system drained).
    So this summers trips are out but there are more summers ( and fall) to come.
    I do want to thank all you guys who helped me through this adventure. A word of advice when it comes the the water pump--------- DON'T........
  23. #198
    Sep 2014
    USA
    Sorry to hear that Lew. Let us know how it turns out when you get it back.
  24. #199
    Durham,Maine
    I had a leaking pump last year, when I say on the 998 where it was, I didn't even hesitate to throw the white flag in!! I think you did a hell of a job, and look at it this way, you got a little closer to your ride!!!
    2012 RTL , Pearl
  25. #200
    Dec 2015
    Oakley Utah
    I had a leaking pump last year, when I say on the 998 where it was, I didn't even hesitate to throw the white flag in!! I think you did a hell of a job...
    what a bummer...I was hoping for a better outcome for you.
    2014 RTL Platinum
Tags for this Thread
