Page 1 of 10 12345 ... LastLast
Results 1 to 25 of 233
    Mar 2015
    forrest above Reno, Nv
    Question Fans running a lot??
    So here we are, 200 miles from home, at a biker rally in Winnemucca, Nv.
    And the fans run a lot.. Checked the coolant level and added maybe 2 cups of water. Didn't Help.
    Any thoughts???
    2014 RTS , Circuit Yellow
    Only a thought, lots of bugs in radiators?
    Mar 2015
    Checked that also and they are clear. Momorn Crickets are out in droves but a good inspection of the screens and radiator show clear. A bad relay or sensor perhaps??
    The fans are not constantly on but more than in the past. I'm puzzled.
    The Spyder ran fine and showed NO signs of overheating.
    Quote Originally Posted by Lew L View Post
    We both have 2014 RT's .... did you check both sides of the radiators ???? ... also is the CAP tight and secure ???.... Mike
    Mar 2015
    Yes and yes. Even checked the oil level properly and as always--- it's where it was 3,500 miles ago
    Maybe I'm just being a worry wart but the has been so good ( Perfect) for years this fan situation had me concerned.
    Thanks for nor responses.
    Lew L
    How about the ambient temp? It has been extremely hot here so early in the season and my temp gauge reads just a bit higher than it has thus far this year and my fans have come on a bit more frequently but not excessively so given the slightly higher temp gauge reading. I too checked the cold coolant level and it was right on the cold line.
    Mar 2015
    Ambient temps in low to mid 80s . Took the out later after checking everything and all seemed fine. I just don't know.
    ........... Mike
    Durham,Maine
    You may want to poke around the water pump and see if you have any signs of fluid dripping out the weep hole, just for kicks!! Good luck
    2012 RTL , Pearl
    Cap tightening worked for us when Linda's heated up at the Grove OK Rally in Oct 2019. Ann and Joe helped take care of that one.
    Sep 2014
    USA
    Were you in stop and go traffic for that to happen?
    Mar 2015
    Yes and no. There were times when I could hear the fans at 20 mph???
    Sep 2014
    USA
    It could happen to have the fans running like that with the temps in the 80's. If it wasn't over heating I wouldn't worry to much about but just keep a eye on it.
    Mine turn on while I am riding at times too. More so in slow traffic too.
    Mar 2015
    OK, thanks triker . Now for the Ryde home from the Run-a-Mucca rally in Winnamucca Nv. About 200 miles. Leaving early!!
    Where is the temp sensor for the fan located??? More for future reference.
    Thanks in advance,
    Lew L
    Durham,Maine
    I am thinking its attached to the fan housing, but I am not sure!!! That's where I have found them before on cars!!
    2012 RTL , Pearl
    Sep 2014
    USA
    Coolant Temperature sensor is on the left side of the engine. Looks like somewhere around the middle of the engine from the picture.
    If you have BUDS you can check that to your gauge too and if they match the sensor is probably good.
    There is a OHM test of the sensor too.
    Mar 2015
    Seriously overheated ( by the temp gage) over in the Gold Country of Cal. Hi temps, fluctuating gauge , fans running alot. Added some water ( not much though). Long tow home ( thank goodness for AAA Premium)
    No smoke or steam, no leaks visible, no loss of power.
    Going into the shop
    Durham,Maine
    Good Luck, hope your back on the road soon!!!!!
    2012 RTL , Pearl
    Mar 2015
    Not soon......... The shop I kinda trust is out 7 weeks for service. Vacation to Pikes Peak and three-wheel rally cancelled!! Oregon ryde with friends cancelled. V-Max is a great back up but not for cross country with my wife.
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    After a 30 mile ride on the highway yesterday, my 5 day old Spyder F3 had the fan running as the rig was idling outside my garage. Outside temperature was 12 C (about 55 F), so outside heat not an issue. I assume this is a normal occurrence.
    Rick
    Dec 2015
    Oakley Utah
    Bummer. Is there anything else you can check out in the meantime, like the water pump and sensor?
    Any fluids underneath the bike? Probably not but thought I'd ask.
    How many miles on the bike? Just curious.
    2014 RTL Platinum
    Sep 2014
    USA
    ENGINE OVERHEATING 1. Low coolant level. - Refill and check for leaks (coolant leaking out of engine leak indicator hole, hoses or clamps missing/defective, cylinder head gaskets leaks, ride plate leaking, etc.). Repair or replace. 2. Air in cooling system - Refill and bleed cooling system. - Check bleeding nozzles in water pump module and cylinder head if they are clogged. 3. Thermostat defective (does not open when engine gets hot) - Replace water pump module. 4. Water pump failure - Inspect water pump drive gears. - Inspect and replace defective components. 5. Water temperature sensor defective - Check or replace. Refer to ELECTRONIC FUEL INJECTION (EFI). 6. Radiator or hoses damaged - Check or replace damaged components. 7. Internal passage blocked in cooling system - Inspect and clean.
    Took that out of the manual
    Maybe Thermostat or pump or sensor??
    Any codes?
    Aug 2012
    Central Coast, CA
    It sounds to me like the old fashioned thermostat is stuck being the mostly likely culprit.
    2020 RTL SE6
    Mar 2015
    Question Finding sensor and pump
    Any codes?
    ........ So....
    No codes, no puddles, no leaking fluid. Poked around to try and find the sensor today. I'll raise her up and see if I can get at it from the bottom. I thought the thermostat was built into the water pump as one unit---- hopefully not. Can the water pump be replaced from the side????
    Thanks all.
    Lew L
    Durham,Maine
    ........ So....
    Thanks all.
    Lew L
    Go on cheapcycle and look at the break down, you will get a idea of what your up to!! Good luck!
    2012 RTL , Pearl
Tags for this Thread
