Results 1 to 7 of 7
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Default canamspyderaccessories F3 hitch adapter
    I'm going to add Pierre's F3/F3S hitch to my F3. His harness comes with a 4 pin flat plug but we have an RT-622 trailer. I haven't been able to find an adapter that will go from 4-pin flat to 4-pin square. Lamont's adapter is the other way around (OEM harness to non-BRP trailer.) Anyone have a lead on the correct adapter?
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    2015 F3-S , Silver
    Idaho
    Cut the flat four in two and tape (or heat shrink tube) one half on top of the other. It'll then fit the square four. I haven't done this myself but others here on the forum have.
    2014 Copper RTS
    Oct 2015
    Lynden, WA
    Hey Roger,
    I did the cut and tape of the Flat 4 to make a
    Square 4 for the hitch on my previous ST.
    It worked without a problem.
    Good Luck, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2013
    Maumelle, AR
    Check with Lamonster Garage. They sell an adaptor that works.
    http://www.lamonstergarage.com/can-a...ter-lamonster/
    2020 RT Limited , Chalk
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Haze View Post
    Hey Roger,
    Good Luck, David C.
    Thanks Dave. It never dawned on me to cut the Flat 4. I needed something quick so in the end I bought a trailer kit at Harbor Freight, cut off one of the flat 4's and spliced it into the trailer's wiring. Now that we're back from our trip I have the time to do it "right".
    Trb-- (Roger)
    Mar 2015
    Indianapolis, IN
    Our best friend has the 4 square on her Spyder and Trailer - and I have the Flat 4 on my Spyder and Vision. I bought a square 4 and flat 4 extension and cut them up to make my own adapter (both ways) - so I can tow her trailer with my stuff - and she can tow my flat 4 with her Spyder if necessary. The wiring of the adapter is sure straight forward.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
