Results 1 to 9 of 9
    Member Podhouse's Avatar
    May 2021
    Pennsylvania
    Default Installing passenger armrests on F3 Limited - do I lose heated handgrips?
    Does anyone know if you are able to keep heated hand grips on when installing OEM passenger armrests? If not what will the passenger hold onto The? The bike is a 2021 F3 limited with the top case. If so did you install them or have them installed? I can't found any information on it.
    2021 Limited , Brake pedal widened Glacial Blue Metallic
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Looked into it on my 2018 F3L and you do lose the heated handrail. My wife decided she would rather have the handrail than armrests. So I saved ~$400.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    May 2021
    Pennsylvania
    Ok thanks for the information.
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I had thought taking advantage of electric installation of the original handrail to install heating on the new armrests.
    Not easy and has not been a very good time to ride but I'll return with the project.
    2018 F3 Ltd. , Black/Dark
    Apr 2019
    Ohio
    Podhouse
    My passenger also lost the heated grips when I installed the BRP am rests on my 2019 F3L. This was ok with her because she didn’t use the heated grips and the arm rests provided a better ride for her. I’m not sure but you may be able to purchase some after market arm rests and still keep the heated grips.
    May 2021
    Pennsylvania
    Update, I spoke with my dealer about keeping the heated grips. They researched it and called back and said I could keep the heated grips with the armrests. I asked if there was a adapter that needed fitted. He replied no they are meant to go together. So I have a appointment for the first part of August for them to install. I will update after. Thanks for the help.
    May 2021
    Pennsylvania
    Update 2, Today I took my 2021 spyder F3 limited to have the passenger heated hand grips installed beside the OEM passenger armrests at my local dealership. From my last phone conversation a month and half ago with them this was possible and the appointment was made. Well turns out they can't be installed that way. So we opted to keep the armrests. It is a shame to lose that option. Also had the first service done at 2,300. Service appointments are 2 months out. Ride safe..
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    I didn't lose heated grips on my RT but wife says she has a harder time reaching the grips around the armrests. Chris
    2021 RT Limited
    2021 Spyder RT Liminted , Marsala Red in Black
    May 2021
    Pennsylvania
    Default Heated grips
    Quote Originally Posted by C. Lee View Post
    Yeah, My handgrips and armrests bolt in the same holes next to the seat. Different models attach diffently. She would probably have the same issue with grabbing the grips too, if it could be attached. My wife said she feels more secure with the armrests. So we will keep them and buy a pair of gloves..lol Thanks for the feedback..
Tags for this Thread
