Results 1 to 14 of 14
Thread: Twitchy
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default Twitchy
    2015 RTL. 18000 miles. BajaRon sway bar. Almost new automobile tires, 17psi F, 20psi R. Had laser wheel alignment. Even on a smooth road, Spyder feels twitchy. Feels like it is jumping around. On cruise control, take right hand of bars and lightly keep left hand on. Still feels twitchy. Is it me, or might something be out of whack?
    Nov 2015
    Chardon, OH
    Have you ever had the Spyder Comfort laser alignment?
    http://www.spydercomfort.com/alignment.htm
    http://www.spydercomfort.com/dealersfl.htm
    Doug
    ”Freedom is not a loophole”
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Snowbelt Spyder View Post
    Had it done by Squared Away.
    Nov 2018
    Waynesboro, PA
    I know you have not ridden for a long time have you checked to make sure the front tire pressures are still with in 1 to 1/2 lbs of each other? If one tire has more pressure than the other it can do that (be twitchy).
    My Spyder
    2012 RTL , Brown
    Feb 2019
    Portland, Oregon
    Open hands and very loose arms on the bars. The steering system is extremely sensitive to ANY input.
    Jul 2014
    Mint Hill, NC
    Suggest too lowering F tire pressure to 15 when you check 'em and see if it makes any difference.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2019
    Palm Bay, Florida
    Will give it a try.
    Dec 2018
    Elanora, Qld, Australia
    Twitchy steering is almost always related to wheel alignment. I run 16 psi front and 22 rear giving me over 20k km and zero twitchiness right up to 140kph. Happy to see you had a successful wheel alignment for the correct 'fix'.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by RazzleH View Post
    I assume you have automobile tires on it?
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Quote Originally Posted by Baron14y View Post
    After having the laser alignment done, has anyone hooked up BUDS and reset the steering angle and yaw rate settings? Laser alignment adjusts the mechanics of the steering/chassis alignment, but resetting all the neutral points is strictly software. If the software doesn't know where dead center neutral is, you could constantly be fighting the steering trying to get back to the old neutral/straight ahead point. A quick but not very precise test is to try and see if your turn signals cancel at about the same point after a turn, or if one side cancels early and the other doesn't want to cancel without doing a very sharp turn.
    2020 RT Limited , Marsala Red
    Sep 2017
    Durham,Maine
    Is it always doing it, every time go out?? Was the wind blowing hard? I find mine twitchy on a windy day, like today was here in Maine!!! And when the road has a lot of crown. And the surface of the road, coarse, smooth, ripely changes make it act up also!! Like said above at times it is very touchy!! Good Luck If it's doing it all the time them I am all wet, and you may have a issue!!!
    2012 RTL , Pearl
    SoFlo
    If you need the alignment and BUDS checked, easy to check, but you need to bring it to me in WPB. Have a ROLO laser setup and BUDS.
    Dec 2015
    Oakley Utah
    Have an experienced Spyder rider take it out for a spin. The only way I know to determine whether it's you or the bike or the road.
    2014 RTL Platinum
    Member George L.'s Avatar
    Oct 2015
    Ft. Pierce Fl.
    where in WPB phone number address 2021 handlebar viberation
    -- George L. 772 971 4693
