Results 1 to 7 of 7
    Aug 2020
    Minsk
    Default How should I properly adjust oem fox front shocks?
    How should I properly adjust oem fox front shocks on my spyder F3-S 2015? I weigh 75 kilograms and sometimes a passenger 50.
    Last edited by Peter Aawen; 05-26-2021 at 09:44 AM. Reason: Removed Prefix - this is a 'How do I?' not a 'How to:' DIY explanation....
    Aug 2013
    SF Bay Area
    There could be a tool in the tool kit or you'll have to buy one from dealer/bike shop or Fox.
    https://www.spyderlovers.com/forums/...cks-adjustment
    2021 F3 Ltd , Magna Red
    Feb 2016
    With the weight of both driver and passenger on the bike, adjust the front shocks to be 420mm (16-17/32") between the upper and lower shock mounting bolts.
    2020 RT Limited , Marsala Red
    This is one way to look at it. What you are wanting to do is to retain the original ride height with spring preload.
    Feb 2022
    New Zealand
    Center to Center on the bolts?
    Aug 2019
    Stoughton, WI
    Correct
    2022 RT Sea To Sky
    Active Member chunkmonk's Avatar
    May 2022
    west virginia
    Quote Originally Posted by Sungate View Post
    Do you know which particular Fox shock is on the bike? It was suggested to me to call a dealer and give them my VIN so that they could tell me the exact part number for the shocks. Then call Fox and have them look it up - they will be able to get you the specifications on the shock and give you suggestions for tuning it to suit your ride parameters.
    2021 F3 L , Stock Plugs (COILS, NOT WIRES!) Stock Brake Pedal Magma Red
