Results 1 to 9 of 9
Hybrid View
    Apr 2021
    PA
    Default 2021 F3 Ltd shudders under acceleration fm 65! Any ideas?
    When i am cruising at 65 and accelerate i get a bad vibration any ideas?
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by 2007276SSX View Post
    Does your F3 have a belt dampner installed?
    2019 F3L , Covid Blue
    Apr 2021
    PA
    I don't know, how do i find that out?
    Apr 2020
    Edgerton,WI
    I suggest you You Tube Can Am Belt Dampner to familiarize yourself. LaMonster also has videos.
    It’s a spring tension roller that rides ontop of drive belt.
    If you still have OEM Kenda tires - this may be the issue. The drive belt can cause a vibration, but I doubt the belt can cause a BAD VIBRATION .... JMHO .... Mike
    Jan 2021
    northeast pa.
    had my 2020 f3-limited out last week.. 300 miles on it.. finnaly took it up to around 75, when i hit that speed a very bad vibration, i whent to 80mph, so i backed off,, it was definitly the belt, i dont really drive that fast, usually 60 and under, but it was the belt for sure. might put the lamonster one on mine.. not sure, because i prolly wont go the fast ..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I was over at a friends house today. He has a F3S and he made an additional one for the bottom of the belt. Said it helped even more. I meant to get a pic, but forgot.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    When I pickup my new 2019 f3s special series, It had the belt damper installed from the factory
    richie spyder
    Dec 2018
    Elanora, Qld, Australia
    Possibly you need to be in a lower gear, particularly if your acceleration is vigorous. Not all vibrations come from the belt.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
