21 RT Limited GPS Plug
I searched the forum and didn't find what I was looking for. I just purchased a Garmin Zumo XT and plan on wiring it to the stock GPS Plug. Do I need to buy the "mating" plug (to plug into what Can Am gives us)? I'd rather plug in than "positap" into it.
Also, has anyone used the Robert Becker Design (https://robertbeckerdesign.com/) locking mount? How secure is it (for daytime parking)?
Thanks much,
David
Originally Posted by Drwerner
I have used a Kradellock since I first became aware of it in early 2016. IMO, it is so secure I leave my Zumo 590 on my Spyder all the time except for overnighting on tour. FWIW, I replaced the Phillips head longer screws Mr. Becker provides with the Kradellock with stainless 7 mm hex bolts because the bolts adjust the tension of the up/down angle of the GPS in its mount and I don't like Phillips head screws for that function.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Awesome, thank you!
Yes, you need the mating plug, although, I'm not sure where you can buy one. I found it was easier using a posi-lock to connect them. On my 2020 RT Limited, what you think was the hot wire, was the ground wire. Be sure to test for the hot wire.
I have a supply of various "bullet" connectors as used on vintage 70's Hondas and Yamahas. I just cut the plug off of my '21 RTL and put female double socket connectors on. One socket feeds my Garmin 396 GPS and the other supplies key-switched trigger to my Electrical Connection fused power plate that I mounted on the other side. Now, when needing switched power (individually fused), I only have to pull one panel to access it. The power plate has a 30 amp fuse feeding it, relay switched from the battery.
BTW, polarity on my '21 was correct.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
I cut the GPS accessory plug end off and used a WAGO connector for my Zumo XT. I have also added Lamonster's fog lights and wired them to the same WAGO plug. I have a 2020 RTL.
I just installed my Tom Tom Rider using the GPS plug on my '21 RT Limited.
I cut the plug end off, then soldered and heat shrinked the connections.
I did notice that there is power supplied all the time, regardless of the position of the ignition switch.
Could this be related to the Fuse 6/7 position?
Exco
Exco
Yes, I believe so. My '21 RTL has the fuse in the as-delivered position and the port is only powered with ignition ON.
1976 RD400c
Thanks! I thought so.
I'm not worried about the cradle being powered all the time, it is how I had it installed on my HD.
Exco
