Page 1 of 2 12 LastLast
Results 1 to 25 of 29
    Active Member bboley's Avatar
    Feb 2016
    Whitewater, WI
    Default Rear tire change needed in Wisconsin - any recommendations?
    Hello,
    I am looking for someplace in Wisconsin/northern Illinois that will put a car tire on the rear of my Syders?
    My Spyder History
    2013 ST Limited - 16,000 miles
    2015 F3s - 48,500 miles
    2016 F3t - TBD
    Jul 2014
    Mint Hill, NC
    Go to this link, insert your Zip code and start calling: https://can-am.brp.com/on-road/us/en....html#/search/.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2016
    Whitewater, WI
    Been there, done that, got the tee-shirt. Found one that said they would (Englhardt's in Madison WI). When I got there this morning for my appointment they said no they only would put a car tire on a Slingshot. I am not happy with them right now!
    My Spyder History
    2016 F3t - TBD
    Quote Originally Posted by bboley View Post
    It's been said " there's No cure for Stupid " .... If they will mount an Auto tire on a Slingshot - which is legally defined as a motorcycle. Then why can't they mount an Auto tire on a Spyder - which is another vehicle legally defined as a motorcycle ????? .... both those veh's REQUIRE auto tires ( according to Fed D.O.T. regulations ) because they both have " J " style wheels / rims. Even H.D. ( Trikes ) come from the factory with ( last I checked ) Dunlop auto tires ..... good luck .... Mike
    Apr 2020
    Edgerton,WI
    Hello,
    I live in Edgerton, I had the truck and body shop @ 2500 Morse St . in Janesville do mine last fall. I brought in the wheel assembly off my F3L
    2019 F3L , Covid Blue
    Feb 2016
    Whitewater, WI
    Thanks, but I'm not able/willing to try to do the removal and installation of the rear tire assembly.
    My Spyder History
    2016 F3t - TBD
    Sep 2017
    Durham,Maine
    It's been said " there's No cure for Stupid " .... fI they will mount an Auto tire on a Slingshot - which is legally defined as a motorcycle. Then why can't they mount an Auto tire on a Spyder - which is another vehicle legally defined as a motorcycle ????? .... both those veh's REQUIRE auto tires ( according to Fed D.O.T. regulations ) because they both have " J " style wheels / rims. Even H.D. ( Trikes ) come from the factory with ( last I checked ) Dunlop auto tires ..... good luck .... Mike
    Because sling shots, are made by Polaris, and they don't have stocks in there tire suppliers!! That is the ONLY thing I can think of Mike,
    2012 RTL , Pearl
    Aug 2019
    Stoughton, WI
    Mad City Powersports will do it. I worked at Engelhart's for a few years. They tow the MFR line on service.
    2022 RT Sea To Sky
    Jan 2019
    Blue Mounds Wi
    When I bought mine at Engleharts, they said they would put any tire on I brought in. I brought it in last fall and they didn't like the veredstien tire because the size was so different. I had to singe a paper taking full responsibility if it messed with the VSS. They mounted it though.
    Apr 2020
    Edgerton,WI
    Hello,
    You may wanna consider asking the dealer if they would install the (newer) Kenda Kanine rear tire.
    Feb 2016
    Whitewater, WI
    Nope, I called madcity they said no.
    My Spyder History
    2016 F3t - TBD
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Mounting CTs on GL1800s got to be dificult to find around here. Went to - Walmart - and spoke to the techs. They have a tech that rides sport bikes and another that mounts tires for him. They said bring it in early on days they are working and no problem! I had three mounted there - they appreciated that I warned them of balancing beads in the tires (they can be dangerous on slick concrete!) Cost~ $12. Haven't tried Spyder mounting, but when the time comes I'll ask. BTW, they never chipped the powder coat on my rims, but a "bike shop" mangled a front rim and tried to charge $85!
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Quote Originally Posted by pidjones View Post
    The problem is genuine motorcycle wheels / rims do NOT have " J " type beads .... so they will never completely seal an Auto tire .... at least without a TUBE .... I had a GW and considered it but decided not to because of this issue .... some folks here go into Panic mode when told Auto tires fit Spyder wheels / rims ..... BRP feels the need to have Auto tires with the " special motorcycle tire " embossed on Kenda AUTO tire bead wheels .... HD doesn't give a Cr*p and uses Dunlops on their Trikes ..... go figure ..... Mike
    Sep 2016
    Rockford,illinois
    Try Loves Park Motorsport in Roscoe, il , Not that far from you
    they put front and Back om mine, last year
    815-636-7636
    Mar 2021
    Illinois
    Quote Originally Posted by KHaacker View Post
    815-636-7636
    They put 3 kanine's on my a few weeks ago. nice people.
    Mar 2021
    Illinois
    815-636-7636
    They put 3 kanine's on mine a few weeks ago. nice people.
    Feb 2016
    Whitewater, WI
    If you don't mind me asking, what did they charge you? They want $300 each to change the rears.
    My Spyder History
    2016 F3t - TBD
    Sep 2017
    INDIANA, USA
    I just had my local dealer replace my rear tire (5/15/21) for $220, this included the Kenda K9.
    Like you I was not able to remove and replace the rear tire.
    Dealer wasn't going to do the (Car Tire) bring in any tire thing.
    Also the job was done in about 30 minutes.
    I hope this is helpful information. . .....
    ENJOY YOUR LIFE WITH A SPYDER
    Member packerfan's Avatar
    Oct 2015
    Amherst, WI
    You might want to check with Donahue Super Sports in Wisconsin Rapids. The service writer may want you to talk with Troy who does a great job servicing my Spyder.
    2020 Spyder RT Limited in Deep Marsala Dark
    Feb 2016
    Whitewater, WI
    Will do, thanks!
    My Spyder History
    2016 F3t - TBD
    Feb 2016
    Whitewater, WI
    They have me scheduled to do the tires! Thanks for the suggestion PACKERFAN
    My Spyder History
    2016 F3t - TBD
    Active Member Bucketman's Avatar
    Jan 2015
    So WI
    Did you have to supply the tire or did they stock the Kanines?
    Oct 2016
    Faribault, MN
    Did you check Rob's Performance in Johnson Creek, WI?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2016
    Whitewater, WI
    Quote Originally Posted by Bucketman View Post
    I supplied the tire. I don't know if they have the Kanines.
    My Spyder History
    2016 F3t - TBD
    Feb 2016
    Whitewater, WI
    Quote Originally Posted by DGoebel View Post
    Yes, they do my oil changes but not the car tire mounting.
    My Spyder History
    2016 F3t - TBD
