2020 limited 75-80 MPH
had my spyder up to 75-80 and i started to feel a vibration,, Belt? do i need a dampener for the belt
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
I too experienced the same now about 3 times. However I very rarely go that fast so probably will wait to get it done later. Perhaps if I start hitting that speed more often I would order the lamonster version which I understand is the best one.
2020 Spyder RT base
Doesn’t hurt to install it…….there is a reason why they make it.
It's a common occurence. I added one of Lamonsters belt tensioners to my '18 and again on my current '21. It eliminated the issue. The drive belt is so long, it produces some harmonic vibrations. Some have been able to eliminate it (or at least lessen it) by loosening the tension in the belt. When I did that on my '21, it only moved the vibration to a different speed. I DO ride that fast so it bothered me. Easy enough to add the belt tensioner. It just takes 2 bolts once you remove the tupperware.
2017 F3L....I adjusted by belt looser to 140 on the Krikit with the rear wheel off the floor. I get a wee bit of vibes in the low 70s, so I go faster or slower.
how much trouble to install a belt tensioner, looking at the lamonster complete kit for my F3
grip puppies
Bajaron sway bar
battery tender
Quadtrac 165/60's
Easy…….if you’re comfortable removing a couple body panels.
it's very common and nothing to be concerned about. Ride more and worry less.
2014 RTL Platinum
After doing much searching, I find that the idler pulley was not installed on the 2020 RT Spyders. I guess that there was enough complaint about the very common vibration problem, that BRP saw that one was needed. So, on the 2021 models, they installed one. Their parts catalog shows one listed for the 2021 models. It is part number 705503291 and costs $48.99. https://can-am-shop.brp.com/on-road/...p/sales/parts/ It appears to have the smaller pulley on it which other posts indicate that it may fail too soon. The lamonster garage version has a larger, improved pulley which would seem to be a better part to have.
