Results 1 to 15 of 15
Thread: Faults galore
    May 2021
    N.H.
    Default Faults galore
    2008 rt..wife brings it down to gas up. Comes home, everything is in Fault mode. ABS,VSS,BDB? LIMP MODE..What the heck happened? Thanks for any help.
    Friend said to disconnect the battery for 24 hrs and see if itbteboots..idk.
    Closest dealer is half a state away . Uggg!
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Mialenafitts View Post
    Check condition of battery…..state of charge.
    Check for clean and tight battery connections.
    2019 F3L , Covid Blue
    .... You don't have to wait that long ( 15 min. ) also after you dis-connect touch the pos. & negative together, then re-assemble assing STAR washers to the terminals ... Good luck ... Mike ... PS I got in the habit of ALWAYS removing the key when parked ... even in my garage .... put the keyat least 6 in. from the ignition switch
    Bossier LoUiSiAna
    Multiple faults & errors: ya load test battery, good solid charge & connections
    May 2021
    N.H.
    Thank you all soooopp much.
    I hope that's the fix. Ill get to it today.
    Thanks again !!!!
    Jul 2018
    Fountain Hills,AZ
    What is the reason for removing key when parked in garage? I've always kept my key in there, am I doing something wrong?
    Dec 2018
    Long Island
    Please explain why you feel it is important to ALWAYS remove the key and put the key at least 6 in. from ignition switch.
    Since 2012, I have always left the key in the ignition, while secure in my garage, sometimes for a few weeks. I often leave the key in the ignition when I meet-up with other riders, while we are standing around talking. This can last 30 min. or more. I have had no problems with either my 2012 or 2014 RT Ltd's.
    May 2021
    N.H.
    Bumming.... battery had 12.34. I topped of with fresh charge.Cleaned everything Installed and exact same issues.
    I call the service shop I guess Monday.
    This hurts, between tires, tune up and new rear hub and bearing, 2 grand in this last two seasons. And here we are dead.
    Bossier LoUiSiAna
    Ick sorry hear Thx for update, unfortunately most dealers closed Monday’s so plz call before 1/2state away.
    May 2021
    N.H.
    Ok..I messed up as far as model.
    Its a GS.
    How do I ,if I can, retrieve the codes?
    Thanks.
    Bossier LoUiSiAna
    Its a GS.
    Thanks.
    https://www.spyderlovers.com/forums/...-Spyder-owners hopefully the RS instructions will work. Please someone correct me if wrong
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I don't know if it will or not but I had some similar whith errors pointing everywhere. At the end the problem was the left habdlebar control. Mine is an f3 ltd 2018 but the crazy behaviour is similar. Hope this helps.
    2018 F3 Ltd. , Black/Dark
    Jul 2018
    Fountain Hills,AZ
    Still waiting for response as to why leave key in or out when parked in garage?
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Before you go too far with the troubleshooting, put a new battery in it. Low voltage will cause lots of errors to pop up. Batteries do also go bad internally.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Bossier LoUiSiAna
    Quote Originally Posted by wilpir View Post
    Just something different for computer but does help throughly going through start up process quicker than battery reboot.
