Colorado front range - what dealers or shops will install Baja Ron sway bars?
What dealers or shops along the Colorado front range will install the Baja Ron sway bars? From reading various forum posts I realize this is a fairly easy job IF you can get the 22-24" of lift needed to get the old bar out and the new one in. Since I don't have a way to do that, I'm looking for a shop that will do the install. Thanks!
Go to a rally. Most have installers if you can’t find one locally. Welcome to spyderlovers!
Read of car ramps getting high enough what year or model
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Have you tried a local dealer? Here in western wa the local dealer installed my sway bar for me.
Yellow 2013RT SE5(Previous)
Champagne Metallic 2017RT LTD SE6
SpyderLovers Sponsor
Not all Spyders have to be up that high. Depends on the year. It isn't that difficult to get the needed height depending on your available options.
Walmart is your friend. For a lot less then someone will charge you to install a bar, you can get a set of ramps that will raise your Spyder high enough and you can pocket the difference.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I have a 2021 S2S. Several threads suggest that ramps won't get the needed 22-24" but I'll check Walmart, Harbor Freight, etc to see what size ramps are available. Thanks.
If U have a jack, use wooden blocks, under the a arms, and lift the spyder in increments, be sure to secure the rear wheel. There are several solutions for lifting the spyder. The Swaybar install at itself is fairly easy.
Somtimes you'll have to think outside the box, but keep in regard, that you work safe...
the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
Spyder F3s 2019 All Black ( Named it: Brutus)
Carbon Items added, just for looks
Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
Swaybar (Ron's)
Tyres Front Michelin Cross Climate+ 175/60-15
Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
Exhaust Bone stock, with a RLS Cat- Delete
Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
Pedalbox, Awesome Upgrade...
Standard car ramps will not get you high enough. I think what is being suggested are loading ramps which you can put on a pickup truck bed or other raised area to get the needed height.
Standard car ramps will do fine for a 2008-2012 Spyder. But they won't come near getting the job done for a 2013+ Spyder. Different animals altogether.
I had mine done by Fremont Motorsports in Florance Co. They have been a Spyder dealer since 2008 and and have a good tech. They will also install car tires. I have been pleased with the work they have done.
Fremont is also only one of 2 places in Colorado to get a laser alignment. Good people, bought our 2019 from them.
Forum
RT Shop Talk
Tags for this Thread
