‘16 F3-L Error Code - any experiences with P060D ?
I’m out on the road, and a fair way from home. After an overnighter where the F3-L was parked outside in 3c temps, I got the dreaded Limp Home mode when I started it next morning. I assumed that the chilly temp (it hasn’t been out overnight in temps that cold before), was possibly the cause. I then travelled 300kms with the limp mode showing, but no change in performance, and the Limp Mode warning disappeared after a stop. However, it has reappeared this morning after an even colder night in the open. I took the throttle grip body cover off and had a look at the throttle connectors, but couldn’t see anything amiss. (Not that I had a clue what I was looking for.) I have to travel some 500kms home and am a loooong way from ANY dealers......anyone else had this code appear?
P060D module:ECM
Throttle Accelerator Sensor (TAS)synchronistic error between sensor 1 & 2.
Throttle Accelerator plausibility check error.
Make sure sensor connector is fully inserted
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Ozzie Ozzie Ozzie
Hey Pete, not that I've ever experienced that code on an F3 before ( ) but given the abnormally low temps of late & your Spyder being exposed to them over-night, it might just be that you've got some moisture/condensation into the handgrip/throttle assembly that's interfering with the throttle sensor's read until it evaporates out.... So maybe you could try spraying in/under the placcy of the RH handgrip & around any of the associated wiring connectors you can get at (only check any connectors for proper connection at the same time too, if you can! ) with some contact cleaner or non-greasy water dispersant?!? Might help, probably won't hurt, so it's your call on whether it's worth a shot or not?!? But if it was me, I probably would!
Ps: were you heading out West? Or up/down the Coast? I thought you had Dealers in just about every direction from Harrington, only just not close?!? So now I'm intrigued??
Thanks, Peter.....I’m hoping that moisture is all it is, although I did have a travel cover over it(maybe heavy humidity). I’m currently in Orange, 3 hours west of Sydney, where it is 5c (feels like -5 because it is sleeting). I’ll see if I can get out and get some water disperser (WD40 does that, doesn’t it?), and pop the throttle body off and give it a shot).
HeliBars Handlebars
Kenda Kanine rear.
Not the throttle body. It's the throttle grip. As Peter Anwan said.
Sorry Billy....I meant the throttle grip body....meaning the cover over the throttle grip connections.... the cold is affecting my brain... (even more than normal). I have just bought some water disperser, taken the grip cover off and given the interior a good squirt. Left it a few minutes and started it up, but limp mode is still there. Hopefully it will take effect over the next few hours.
Many thanks
HeliBars Handlebars
Kenda Kanine rear.
No help to you Peteoz but this is an example of one reason why I keep my trusty old GS SM5. Reliability ain't the Spyder's strong point with newer models as we see repeatedly. Lotsa Ulysses folks there to offer advice and help no doubt. Good luck with it.
If the problem is caused by moisture. Either by a leaky connector or Hall sensor. Then It needs to fixed when you get the chance. Spraying with WD40 even if it works temporarily. Is not a fix. It is sealed and should work, even submerged under water.
Thanks Billy......yeah, I have no intention of just leaving it. My current concern is that I have to travel on some pretty lonely roads to get home (or even close to a dealer), and I just wanted to take all the “precautions” I can. It has so far presented no issue other than disabling cruise control when the warning is active. I believe I’ll just make a run for home, (550km) as my nearest dealer is 400km away anyway and are closed today. As I’ll be leaving here in a few hours at around 1c temps, I’m sure I will start out with Limp Home mode, but I hope that when I reach slightly warmer climes, it MAY go away. Cross your fingers for me
HeliBars Handlebars
Kenda Kanine rear.
Thanks Freddy.....Yeah, I know exactly what you are saying...... I have never had a moments trouble during the last 5 years, but it is frustrating when you can’t resolve an issue on the road due to the electronics
HeliBars Handlebars
Kenda Kanine rear.
Just for info.....”Limp Home” was on when I started the Spyder at -3c this morning. It disappeared when I restarted the F3 after fuelling up 30 minutes later, and stayed off for 4 hours, then reappeared 20 minutes before I stopped for the day. It was running in 18 degree temps at the time, so it looks like it may NOT be moisture related. I am now overnighting 3 hours from home. I’ll ride it home tomorrow (hopefully), and then call my “new” dealer (the old one just quit their BRP agreement). They are 2.5 hours away, so I’ll see if they are prepared to order a replacement part that relates to the P060D error code before I take the F3 down for a fix.
HeliBars Handlebars
Kenda Kanine rear.
