Results 1 to 4 of 4
    Aug 2016
    Cleveland, Ga
    Default What's the correct Krickit reading for an RT's belt tension?
    What should the Krikit reading be for a Spyder RT be, for the correct drive belt tension?
    Last edited by Peter Aawen; 05-12-2021 at 04:50 PM. Reason: Prefix & title - this is a 'How do I?' question not a 'How To: DIY' guide. ;-)
    Sep 2012
    Stetson, Maine
    Depends on model year. Older models have different specs than later models. Check out this post. https://www.spyderlovers.com/forums/...on#post1529743
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2012
    Stetson, Maine
    Last edited by Peter Aawen; 05-12-2021 at 07:07 PM. Reason: Added link just to be sure to be sure! ;-)
    New to Sue and I
    Quote Originally Posted by joekeys View Post
    Tension depends on year and model .... You didn't provide that info .... But I did check your other posts .... for 2015 RT I ONLY measure it ON-THE-GROUND. , and like a little less tension than OEM spec.... so mine is around 160 lbs. measured in the middle of the belt..... At that tension my belt vibes dis-appeared ..... Mike
