ACS suspension settings
2015 RTL. I always thought that setting the bar graph to the top would give the stiffest ride. If I read the information below from the owners manual, it is the exact opposite. Seems illogical. Please advise.
ACS SUSPENSION SETTINGS
BAR GRAPH
INDICATION IN
MULTIFUNCTION
GAUGE
RIDING
POSITION
1 (top) Lowest
2 Low
3 Middle
4 High
5 (bottom) Highest
Think of it more as "ride height" than "stiffness".
Air is a much-more progressive spring than the coil spring that it assists. By shooting more air into the bag, you will raise the ride height and allow more travel for the rear wheel. By bleeding the air out of the bag, you will lower the ride height, reducing wheel travel.
Let's say there is a 2x4 in the road. If you have a total of 6" of travel (I have no idea how accurate that is for an RT), you will likely use up 2" of that just sitting there. As you go down the road, running over that board, you will use up half the remaing travel available. If you have a passenger on board, you might sink another inch, meaning that running over the board will take up 2" of just 3" available, increasing the possibility of bottoming out. Adding air could raise you up to having about 5" available travel, so running over that 2x4 will barely be felt. In other words, a MUCH smoother ride.
If it were up to me, I would remove the coil spring and go entirely with an air spring, but I'll settle for the way the CanAm did it.
Also note that the system is self-leveling. If you adjust your headlights to be just right for you, then load up the saddlebags and trunk AND have a passenger hop on board, the compressor will kick in and add air to the bag, bringing the rear suspension to the same height and your headlights will be aimed just right again.
It's a bit tricky to see the system actually work. Several things have to happen to see it. Bike must be running. Transmission NOT in neutral. Parking brake OFF. I put chocks ahead of and behind the front wheels so the bike would not roll. Had the bike on our back patio with the lights shining across the yard, with a fence in the distance. When the ride height stabilized, I stood on one of the passenger floorboards and saw the hedlights go high on the fence. As the compressor came on, the lights went back down to normal. My son then stood on the other passenger floorboard, the lights went high again, the process repeated. When we both got off, the lights were, of course very LOW. The valve opened up to release the extra air, the lights came back up to normal.
Nice system overall, but don't think of it as "hard" and "soft", think of it as "higher" and "lower".
HER ride:
2017 RT-S SE6 Pearl White
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
So, if I understand what you are saying, particularly with a passenger, it is better to be at 5 rather then at 1?
5 will definitely be better than 1, with a passenger or without.
We usually run it right in the middle. I don't remember if there are 5 positions or 7, so it's either 3 out of 5 or 4 out of 7.
Overall ride will not be any softer or stiffer, but there is increased ability to soak up larger bumps.
HER ride:
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
oops
That's just one of the many things they got bass ackwards in the manuals.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Hey Baron. Yeah, don't try to make sense out of the manual. Your eyes are not deceiving you and your logic is not faulty. It's been backwards from the very beginning. Mentally, flip the words (top) and (bottom). A basketball that has 50# of air in it is firmer and harder to squeeze than a basketball with 10# of air in it. High air pressure, firmer ride, and high ride position is at the top of the scale on the display, and low air pressure, softer ride, and low ride position is at the bottom.
Keep in mind that there is that sensor on the left underside that connects between the frame and the swing arm. So, no matter what setting you are using, if your passenger gets on the back, the increased weight causes the suspension to sag a bit more. That is picked up by the sensor which causes the air compressor to add more air. The suspension height will then return to the original position with more air pressure, compensating for the increased weight. And the reverse is true when the passenger gets off. The suspension rises and air is vented off. The automatic function of the system doesn't actually care what air pressure is. It works by controlling ride height / amount of sag of the suspension.
The middle position always worked for us.
Doug
”Freedom is not a loophole”
