Results 1 to 7 of 7
    Nov 2020
    Lincoln, Nebraska
    Default Pretty good click 10 seconds after shutting down.
    On my 2016 RTSC6 I have discovered the last couple times when I shut it down after riding I hero noticeable click in the front area of the bike. The only thing I can think of is the eyebrows are shutting down after riding with the highbeams on. The parking break has already been set when this occurs.
    Mar 2015
    forrest above Reno, Nv
    It may very well be metal contracting as it cools---- probably the exhaust system.
    2014 RTS , Circuit Yellow
    Idaho
    I believe all Spyders hold the headlights and other items on power for 20 seconds after turning off the ignition. Leave the brake off next time you shut it down and see if the brake nagging beep ends the same time as the click you hear. That will confirm it's all part of the shutdown process.
    2014 Copper RTS
    Sep 2012
    Stetson, Maine
    I agree with above post...
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2017
    Durham,Maine
    x3
    2012 RTL , Pearl
    Oct 2020
    Arizona
    I run my head beam 360 TricLEDs all the time. And yep I have shutter drop at the end of the delayed shutdown. Actually someone pointed out that the low beam shutters go up, not down. As the light is inverted in the lens.
    Nov 2020
    Lincoln, Nebraska
    Thanks all!
