2015 RT OEM Shocks - how long do these things last?
I have 66,000 miles on my 2015 RT-S. The front shocks are the ones that came with the Spyder. How long do these things last. There is an old say "you grow older with your bike" in other words you tend to make adjustments to your riding to compensate for things that should be replaced.
Looking for those that have replaced the front shocks because of wear. Not necessarily looking for the performance differences between OEM and Aftermarket.
Willie
Willie
I have a 14 RT with 57,000 mi. my shocks are fine ( they are at a more up-right angle, but I doubt that makes any Wear difference ) ..... Mike
I’m at 71.6K and my shocks are fine.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
I would judge it from, what kind of body roll are you getting when you go into a corner? And when you hit a bump in the road is it pounding threw it, with maybe a little bounce? When you park it next to another bike same model same amount of weight closely in the front, how's the stance of the bike across the a frames? Like said above, if you have driven that bike from new, you will grow old with it, and until you change the set up you will often times not know when it's going!! I have never like the body roll that my bike had from day one when I rode it from the start, this year I changed them with a set of Elka2!! What a change, whole different bike in the bumps, corners, and over all feel!!!! I guess if it's not broke, why fix it, if it's giving you the ride it did from the first time you got on it, your good to go!! Your bike, your ride!!!! Good luck!!!
Honestly, the OEM shocks are rather bargain bin models. I would suspect they are significantly degraded by the 50k mile mark or less. It doesn't mean they don't work good enough. A Spyder isn't a moto GP bike, so it doesn't demand top shelf stuff so it's unlikely you'd notice the degradation in performance, short of being blown and leaking. The only way to tell for certain would be to remove them from the bike and separate the springs and then manually check the compression and rebound dampening of each shock.
2020 RTL SE6
There are hearts breaking all over the world tonight.
https://www.youtube.com/watch?v=oWV7TC6E5ww
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
SpyderLovers Sponsor
Shocks lose their abilities slowly over time. It is a slow, subtle degradation. Most do not notice the reduction in handling until it is pretty significant. BRP, to their credit, has improved their stock shocks over the years. How long they last depends on a number of factors. But they should be good for at least 50k under normal driving conditions. This doesn't mean that you won't get improved ride and handling from upgrading your stock shocks. Even if they are brand new. But your stock shocks will do all they can for quite a few miles.
