Results 1 to 15 of 15
    Sep 2017
    Knoxville, TN
    Default Foam Deteriorating Behind Panels - anyone else??
    Has anyone else had to replace the foam behind the black side panel that is in front of the oil filter? I have a 2014 RTL. My husband did an oil change today and noticed it was deteriorating.
    Jul 2014
    Mint Hill, NC
    Yes, the heat gets to them; mine is going south too. I think but before ordering I would call a dealership parts dept and confirm if it is the RH Upper Lateral Panel Foam, PN 705009314 (a changed PN found on Cheap Cycle Parts at $30.99, ouch). It's to be sure just what panel foam it is because of the way BRP displays some of their parts views.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Quote Originally Posted by Orangecrush View Post
    Yes this will occur over time .... If you want to change it / them I would use something else .... google heat SHIELD and dozens X dozens of products will show up .... some are even Spray - On .... others are a combination of materials with an alumin. top layer with a stick-on bottom layer ( after foam removal clean well, lastly use alcohol ..... goos luck ... Mike
    SoFlo
    Same happened to our 2014. I removed all the foam sections. Replaced with upgraded insulation we use on aircraft interiors. Was worth the effort since the Spyder is now quieter and better insulated to keep heat away from the riders.
    Feb 2012
    Spring City,Utah
    PMK what is this aircraft interior insulation called? Thanks for the info.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2017
    Knoxville, TN
    Thanks everyone for the suggestions!!
    SoFlo
    It’s called expensive...I used some leftovers from when I installed the upgraded soundproofing in the Beechcraft.
    SoFlo
    https://skandiainc.com/product/e-a-r-damping/
    I looked ....54" X 10 ft. ..... that's a lot of product ..... I didn't check the price, but I imagine " aviation " stuff isn't cheap ..... I would check " Summit racing " ...... good luck .... Mike
    Apr 2019
    Clinton, MS
    One site had that size for only a mere $294.
    Jul 2014
    Mint Hill, NC
    Thanks for the words, Mike. Old, dead brain couldn't come up with them at the end of a busy day. Will do mine at next oil change.
    Cognac 2014 RT-S
    Holy *hit .... Summit racing has stuff that's just as good ... in smaller sizes waaaaaaaaaaaaaaaaay less money .... jmho .... Mike
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    Probly cheaper than BRP.
    The best substitute for brains & knowledge is....................silence.
    SoFlo
    Considering the Skandia stuff I used was free, it was a bargain for me. As for just as good, maybe, but unlikely.
    The Skandia soundproofing I used is a self adhesive product. Yes, there is a layer of sound absorbing foam, and on top, adhered to the foam is a layer of silicone rubber sheet that is about 1/16” thick.
    Far superior to oem stuff that turned to goo. Reduced the heat and noise from the vehicle that the riders feel or hear.
    Being a certified part 25 aviation product, it must also pass burn cert tests. My guess is that the materials used will not burn and catch fire, and if they did, the materials must self extinguish.
    Merely using up stuff we had rather than discarding it.
    I did have a look at Summitt Racing. Maybe a misprint, but the spec states the Scott Drake Black insulation is almost 1 inch thick. Oem is pretty thin, likely 1/4” or maybe 3/8” thick. Stuff I used was about the same. Possibly there is clearance, but an inch is kind of thick.
    Apr 2019
    Clinton, MS
    I'd call it recycling and doing your best to save the latest blue finned horny spotted wiggle toad of the week.
