2014 RTL headlights not lighting up
On a recent ride my wife (driving in front of me) noticed my headlights were not on.
I've checked R6 by swapping with hers and that's not it.
I've not done anything to the bike since I last rode it a year ago, except to swap out the dead battery.
Any ideas of what to check next?
2014 RTL Platinum
All relays & fuses. If fog lights come on when running should indicate most is working, double check /swap bulbs as well if not too much trouble. Maybe good time upgrade to LEDS would want know has proper power first.
I have LEDs for headlights and fog lights, so that's not it. Both headlights are not working so swapping them is not likely to accomplish anything.
I agree I need to verify power to them, but where to start? The 2 fuses that I pulled and R6 are good. Everything else electrical seems to be working.
Thanks.
2014 RTL Platinum
Hey Pete. Which fuses did you check? Looking at your owners manual it would be Right side box JCase fuses, (the square ones) F4 and F5?
By the way, I had a premature failure of an LED lamp with my first set of LEDs. Pulled out the assembly, put in an old good bulb, it lit up just fine, got a replacement set of LEDs under warranty. Point is that it wouldn't be unheard of that they could have failed around the same time. Try a good bulb.
Doug
”Freedom is not a loophole”
Hi Doug. I did not check those square fuses. Not sure how to remove them; do I just pull them straight like other blade-type fuses?
I suppose I could pull the Tupperware and check for power at the two headlight connectors. Thanks.
2014 RTL Platinum
They come straight-out like the little ones. There's probably a special plastic tool that's preferred, but if you are careful, needle nose will do.
https://www.waytekwire.com/item/582/JCase-Fuse-Puller/
Doug
Ya if still have the old H bulbs Test with those, engine has to be running though. E51B230F-F513-4D6F-9E21-00B1E03320AA.jpg adapter for other bike also uses H4 bulb
Thanks for the diagram, but can you please explain it?
2014 RTL Platinum
If you have a meter go from ground to the low connection and see if you have voltage while the bike is running.
Yes, I have the tools and meters needed. Which connector are you referring to?
2014 RTL Platinum
Make sure the high/low beam switch is not bad or stuck in between HI/LO??? Also relay(s) http://www.can-amtalk.com/forums/top...eadlamp-relay/
Originally Posted by bluewoo
I did replace R6 relay with a known good one and that didn't help. Is there another relay I should check?
It sure would be nice to get a wiring diagram for the lighting circuit....
2014 RTL Platinum
Okay, I've checkout R6 in the left box. It's good.
Checked out the following in the right fuse box, and they are all good; J4, J5, R1, R2
Nothing left now but to pull the Tupperware and check the actual bulbs. What do they say in troubleshooting; it's always the last thing you check, right?
2014 RTL Platinum
Ozzie Ozzie Ozzie
But surely that's ^^ only true if you actually find a fault/get a result???
Cos if you can't find anything to fix or resolve the issue, then by default ( de fault of you can't find anything to fix! ) that particular ' issue' becomes an ' undocumented feature'!! This is widely recognised as a prime tenet of ' the BRP Method of Beta-testing'.....
Well, I'd better figure it out 'cause I've got no headlights working...
2014 RTL Platinum
Ozzie Ozzie Ozzie
The more you tell us, the more it sounds like it's gotta be a lack of power at the headlight globe plugs, or possibly a matching pair of blown globes??!
Any chance you could've had a rodent or two in there behind the headlights; or maybe have pinched the wires somewhere?? Still, either way, it does sound like it's time to pull the tupperware and get in behind those headlights to check things out.... Sorry.
I'll keep y'all updated as I methodically track this rascal down! But now, it's time to turn in for the night. Take another crack at it tomorrow.
2014 RTL Platinum
Make it as complicated as you like, but pretty much if you have the ability to hear the shutter cycling the wiring and power is likely fine. Change the bulbs and quit screwin around.
Bulbs should be the first check. If fuses failed or relays fail, fine, but not that common, AND for a fuse to fail it takes time to sort out.
Bulbs are known low life span items, just like front pulleys, fix it and be done. Not difficult, but if beyond your ability get help.
Thanks for the reminder to check for the shutter cycling between high and low beam. I thought I'd done that, but maybe not.
As for the last comment, I'm not ready to admit I can't do these things myself. When that's true, it's time to get rid of it I think.
2014 RTL Platinum
Thanks for the tip on cycling the hi/lo beans. I did that and yes, the shutter has power. Wish I'd done that first, but at least I've learned a few things about my bike I didn't know before.
Time to change the bulbs probably. What is the consensus these days on the best LEDs to get? I'm inclined to try Lamont's.
2014 RTL Platinum
The headlight connector when you disconnect it from the bulb. But sounds like you are going with LED's. I just installed Benebolt LED on my RT. But have not had time to finish putting the Spyder back together yet to tell you if they are better.
Always seem the LED are either going out at the worst time and really liked the Benebolts on my vehicles so far.
When you get the bulbs out make sure to check to see if there is power there before putting everything back together.
I had replaced my headlights and fog lights with LEDs from a former vendor here 4 years ago. The left headlight went dead just a few months later and I replaced it under warranty. Thankfully my fog lights are still good because those are a real bear to replace, especially the left one.
I've just ordered a set from Lamont; they're different from the ones he was originally selling I think. So, the technology and marketplace seems to be constantly evolving.
2014 RTL Platinum
Replaced my led headlight bulbs with Lamonster kit today. Now they work again. That's all that was wrong with them, apparently.
2014 RTL Platinum
