Results 1 to 3 of 3
    May 2021
    FL
    Default Found a tiny Screw on the oil drain plug!?!
    Just gave my wife's new 2011 spyder rt se a total once over we got it with 15000 mi and its emasculate got the skin off and there was oil every were I figure its because it had 5 qt of oil.
    The super odd thing is I found a tiny allen screw attached to the magnet drain plug. gona be up all night wondering how it got there.
    Oct 2015
    Lynden, WA
    Default Oil gallery plug set screw.
    This is not good. Could be an oil gallery plug set screw.
    See post #3
    https://www.spyderlovers.com/forums/...light=setScrew
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Nov 2015
    Chardon, OH
    Because the OP has a 998 engine, this thread is probably more appropriate to his problem:
    https://www.spyderlovers.com/forums/...l+drain+magnet
    Jimmy, read over the whole thing. Lamont came up with the answer. It doesn't sound like it will result in sudden death. Perhaps you can PM finless Bob or Lamont and get recommendations. Finless may have even made a video on this. Check his YouTube channel.
    Doug
    ”Freedom is not a loophole”
Tags for this Thread
